Hood lock?
Old Feb 17, 2002 | 04:10 PM
justinCO's Avatar
Default Hood lock?
Are there hood locks that provide better security than the stock ones? I would like one for my GSR, but couldn't find any previous posts on these. Where would find a better hood lock, any recommended brands? TIA.
Justin
Old Feb 17, 2002 | 07:48 PM
nsxxtreme's Avatar
Default Re: Hood lock? (justinCO)
manual hood lock the electric ones are junk at least the ones I've seen are.
Old Feb 18, 2002 | 05:29 PM
MachAF's Avatar
Check out what http://www.autotoys.com has.
I'm probably going to get that electric one they have.
[Modified by machaf, 7:29 PM 2/18/2002]
Old Feb 18, 2002 | 07:10 PM
nsxxtreme's Avatar
Default Re: Hood lock? (machaf)
You guys have really got to learn how to link to what you are talking about. Its really a pain to try to find what some of you are talking about some times.
I believe this is what he is talking about. This is what the one I was talking about looks like. It worked good for me.
[Modified by nsxxtreme, 4:45 AM 2/19/2002]
Old Feb 18, 2002 | 08:24 PM
justinCO's Avatar
Default Re: Hood lock? (nsxxtreme)
How does that manual one work? You have pics by chance? Do you pop the hood like normal inside the car then use a key through the hood gap to unlock it? Thanks for the help everyone.
Justin
Old Feb 18, 2002 | 09:45 PM
nsxxtreme's Avatar
The key is inside the car, you unlock it, then pop the hood. The cable goes from inside the car out to the hood. No pics sold car sorry.
Old Feb 19, 2002 | 03:18 PM
nsxxtreme's Avatar
Looks like you guys will have to search the links no longer work. It looks like they change there locations so you can't link to them. Basically they want you to shop.
Old Feb 22, 2002 | 07:16 PM
Renegade's Avatar
the hood lock with the cable sucks because as long as they can get in your car( by braking a window) they can cut the lock off and yank on the cable to open the hood.
Old Feb 23, 2002 | 01:10 AM
nsxxtreme's Avatar
Default Re: Hood lock? (98401R)
OK... and your point is. Lets figure out what the hood lock was designed to do. Lock the hood and protect the siren not protect the car from being broken into. These cables are not that easy to cut. It would be 10x easier to just disconnnect the alarm since your already in the car.
Old Mar 1, 2002 | 04:54 AM
jamal-188's Avatar
But woudn't the hood lock also protect thieves from hot wiring the car from the engine compartment if they couldn't get your car started from inside? Also, why do the electronic hood locks suck, are they cheaper quality or easier to bypass? I'd just rather not run that wire from the mechanical ones inside my car and hide it somewhere under my dash so they couldn't just yank it out!? Not sure what to do?
Old Mar 1, 2002 | 10:11 PM
nsxxtreme's Avatar
Default Re: Hood lock? (jamal-188)
If they can't get it to start from the inside they aren't going to get it to start from the outside. The electric hoodlocks I've seen only lock when the alrarm is going off. Very easy to bypass.
Old Mar 2, 2002 | 01:10 AM
jamal-188's Avatar
Oh, I thought you would hook the electronic hook lock up to a switch or something and hide it under the dash. What would you recommend I do so they can't start my car from the inside. I have an alpine alarm but I have a feeling it won't do jack if somebody knows what they are doing?
Old Mar 2, 2002 | 09:14 AM
nsxxtreme's Avatar
If someone knows what there doing there isn't much you can do.
except this
Old Mar 2, 2002 | 12:42 PM
o_Rage_o's Avatar
the whole point of adding all these layers to your system is to try to make it harder to steal so that you can have a better chance of it being discovered, by you or someone else.
If someone knows what you have in the car, and wants your particular car badly enough, they'll go through everything on their "how to steal a car" checklist.
The hoodlocks will help, since theives can't externally disable your alarm by just popping open the hood and yanking everything. There will be that extra time required to disable the hoodlock.
Old Mar 2, 2002 | 01:26 PM
nsxxtreme's Avatar
Default Re: Hood lock? (o_Rage_o)
The problem thought with the electric ones is that most theives know how to pop the hood from outside without setting the alarm off. If the alarm doesn't go off the hood stays unlocked
Old Mar 2, 2002 | 11:52 PM
GSRaCeRbOI's Avatar
cant you wire the hood lock to an armed output on your alarm.. so that right when you arm the alarm.. it locks the hoodlock.. and then wire it to another channel on your alarm to unlock? im asking this as a question.. but i'd assume this can be done..
Old Mar 3, 2002 | 09:53 AM
nsxxtreme's Avatar
Default Re: Hood lock? (GSRaCeRbOI)
OK, here is a guess as to why you can't do that. I can't get on auto toys site for some reason, so I can't check out the specifications. If anyone has one of these electric hood locks, anyone have any idea on how much current these require? I'll reserve my comment until after I get some more info.
Old Mar 3, 2002 | 01:50 PM
GSRaCeRbOI's Avatar
yeah im not exactly sure how the electric ones work either.. i was just thinking it was a motor w/ a slider pin like a deadbolt.. so it takes constant power/current draw for the thing to be activated? i searched to try and find one online to see how it works and everything.. couldnt find it.. so if anyone has any links link it..
Old Mar 4, 2002 | 06:15 PM
nsxxtreme's Avatar
Default Re: Hood lock? (Teken)
This is very different from the electrical ones I've seen. I must be getting old.
I will have to check out the electrical ones more closely next time around.
Old Mar 5, 2002 | 04:21 AM
GSRaCeRbOI's Avatar
the fully automatic one sounds cool for me i know i have a timed armed output and some open channels = )... thanks for clarifying everything Teken .. yeah it didnt make much sense to me that it would have a constant draw cuz then the battery would go dead..
Old Mar 5, 2002 | 05:13 AM
nsxxtreme's Avatar
Teken,
to get some more info on this.
Does the hood stay unlocked all the time and locks when the alarm goes off?
Or does it require a seperate channel on the alarm to unlock?
Or does it work like your normal doorlocks, locked armed, unlocked disarmed?
Use your imagination as to how long it takes me to remove it with a simple screw driver??
No longer than it would take me to disable 90% of the alarms out there.
[Modified by nsxxtreme, 6:17 AM 3/5/2002]
Old Mar 5, 2002 | 09:23 AM
Mr.Squeeze's Avatar
Just to clarify this topic for you all... There are several methods of securing the hood assembly. Some are better than others...
Some cost more than others... Some actually come with a lifetime warranty against defect in workmanship... And yes the better ones have a safety bypass switch / cable to protect you in case of a failure in the said unit...
1. Simplest and least effective mech is a hood lock. Where the actual two front corners are drilled to allow a hood pin or actual pad locks to secure the hood. They have been used for years in the pro-race series to protect the race car drivers against unexpected hood blows... They do not afford any measure of security per say, just safety as the latch pin / pad lock are easily circumvented... Added they are labor intensive to install correctly and are ugly to see...
2. Manual cable through fire wall bolt / pin mech... This affords more security to the owner than the above. The down side is that the mounting points must be drilled into the frame of the vehicle on both sides. One for the latch, and one for the sliding pin mech. The other down side people fail to realize is that the mechanism is (only) as secure as the mounting point to the key tumbler assembly...
3. Semi & fully automatice hood locks: Semi denoting that only half of the process of latching / unlatching is controlled by the alarm CPU or actuator switch / user... The other process entails more intervention on the part of the user to access / open the hood...
4. Fully automatic: The system is integrated into the existing alarm system that has a negative output. The unit has a very small soleniod to release the latching cable that is circumventing the opposite pull of the factory (OEM) latching mechanism...
There is NOT a constant draw of current on the vehicle at any time after the unlatch process is over and done with. Which by the way is timed for aprox 15-20 seconds to allow the user to simply pull the factory hood release cable...
I hope this clarifies this very simply issue...
Regards
Teken
i will be geting me one of the fully automatic one.i had the hook lock with the cable and i never thought about someone could take a srew driver and take it off lol
Old Mar 5, 2002 | 02:49 PM
nsxxtreme's Avatar
One last question Teken,
How is unscrewing it going to do you any good the lock doesn't unscrew. The only thing I can think of that you are talking about is what the lock attaches to. If this is so, then I am wondering how you are going to unlock it. The cable is bolted at the other end. I am scratching my head at this one. If you don't want to post it IM me or e-mail me. Thanks.
dc2415
Audio / Security / Video
Mar 11, 2009 02:49 PM
JSR
Oct 22, 2004 04:54 AM
Hacemuy
Sep 14, 2004 12:03 PM
Soon_2b_evil
Mar 24, 2004 03:20 PM
