hey guys need help
Old Jan 12, 2007 | 05:13 PM
409-Ef8's Avatar
Default hey guys need help
hey guys i have a little issue with my car its a 88 civic sedan dx im putting in a new stereo and the factory one will not hold memory so i said it must be the stereo so ill change it and needless to say thats not the issue the new one will not turn on unless i have the 12volt constant and the 12volt ingnition together
Old Jan 12, 2007 | 05:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: hey guys need help (409-Ef8)
And what are you connecting the two leads you, joined together, to?
The yellow/red in the stock radio harness, [ACC.]?
Or the white w/yellow or blue tracer, [12V+ constant]?
The constant power lead on most Honda/Acuras are protected by a 7.5A, [hot at all times] fuse in the under hood fuse box, Depending on the aftermarket HU you have you may or may not be able to use that circuit, [new HU needs more then 7.5A of current] if that is the case, run a fused 12- 10 gauge power line from the batt. to behind the HU connect the HUs 12V+ constant, [yellow] to it, don't forget to cap off the stock 12V+ constant, and replace the fuse, if blown. DO NOT replace with bigger fuse, it is also often used as memory for your ECM/ECU. 94
Old Jan 14, 2007 | 12:56 AM
imroadk1ll's Avatar
how do i take out the radio?
Old Jan 14, 2007 | 06:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: (drivingmylif3)
Not sure I understand, "take out the radio" have you not pulled it out already and tried the aftermarket one? 94
Old Jan 14, 2007 | 12:27 PM
imroadk1ll's Avatar
Default Re: (fcm)
i meant the audio unit. u know the one with the buttons for fm am cd player?
Old Jan 14, 2007 | 01:28 PM
fcm's Avatar
fcm
Old Fart
I you mean the OEM HU, [head unit] it is held in by two 8mm/Philips machine screws that go through the rear support bracket into the extended lip of the HUs bottom panel, much like on a 93-95... http://www.installdr.com/Insta...7.pdf access to the 8mm machine screws, [bolts] will be a little different on your 88. 94
Old Jan 14, 2007 | 10:40 PM
imroadk1ll's Avatar
Default Re: (fcm)
thanks now that sounds more right
AnonymousSquid
Audio / Security / Video
Jan 10, 2008 07:51 PM
oemDC2
15
Jan 18, 2007 08:13 PM
Liquidgsr
Jan 13, 2007 09:21 PM
@.com
Aug 30, 2005 07:37 PM
andrekun
Jun 21, 2004 02:43 PM
