Help w/amp and sub install
Are you using a non-fading output???
if so, look in your manuel and it will tell you how to turn it on
i have the excelon 817 and i need to do that
have you tried another set of pre-outs?? different RCA cord??
if you can maybe a different amp if those don't work
also, make sure the level for the non-fading pre-out isn't set all the way down
I cant find any on/off button for the sub in any menus. If anyone else has detailed help for kenwood exceleon 616 with mtx thunder 4122 amp and mtx t612 sub/enclosure. Thanks
there should be a button on the deck that will have "nf' listed on it
mine is the "AM" button, you just hold it down untill it says "non-fading on/off"
use a 9V battery to "POP" the speaker. If you hear something then, use a portable CD player witha 1/8" ended headphone plug and a pair of RCAs on the other and plug them into the amp. If you hear something it's somethign else further up the signal chain.
pbizzlegsr
Audio / Security / Video
Jun 28, 2007 08:00 PM
boostincoupe
Nov 7, 2005 08:14 PM
