4 speakers on a 2-ch amp???
Old Jun 11, 2003 | 06:18 PM
redman223's Avatar
Default 4 speakers on a 2-ch amp???
I was wondering if anyone has done this before and how well does it work? Right now I have an Audiobahn a2601x amp that pushes 150x2 RMS @4ohms, and I have a set of polk momo components (capable of handling 150 each) in some custom kicks up front, and plan on getting some 6x9's in the rear, probably in the same power range.
Right now, I dont have the gain turned all the way up, so I was wondering if anyone has ever hooked up 4 speakers to a 2ch amp??? Could I just wire them up in a 2ohm load and get more power, so they would theoretically still be getting 150 watts but @2ohms instead of @4ohms???
Oh yeah, and how exactly would I do that???
Old Jun 11, 2003 | 08:04 PM
PetroGuyX's Avatar
i did it with my excelon 2 channel, just put one set of speakers on one channel, and then other on the other channel, you can do it with the fronts and backs, or the lefts and rights, either way it works fine, cheaper than doing a 4 channel, you just dont have the capablility of fading or balancing, you lose one of the two depending on how you set it up
Old Jun 12, 2003 | 05:18 PM
redman223's Avatar
Default Re: (PetroGuyX)
So if I had them hooked up fronts and rears each into their own channel, if I wanted to quiet the rear a little bit i could just fade that channel slightly?
Old Jun 12, 2003 | 07:22 PM
PetroGuyX's Avatar
pretty much
Old Jun 15, 2003 | 04:36 PM
ATF Kuk's Avatar
it wont be stereo anymore if u do that, it will be mono. u will lose channel seperation.
Old Jun 16, 2003 | 02:27 PM
redman223's Avatar
Default Re: (ATF Kuk)
Well wont it be the same in a way??? But It will just be with 2 different speaker sets? The front speakers will be together and the rear will be together, in the left and right channels respectively, and true i will lose left and right fade, i will still have front to back (by using left and right fade)
I'll make sure I post up when I finally install them, I dont have any money left right now, I just bought a 150amp alternator and some ANL fuses so I wont be able to buy the speakers for the rear for awhile.
Old Jun 16, 2003 | 02:31 PM
greebler's Avatar
just make sure the amp can handel a 2 ohm load.
Old Jun 16, 2003 | 02:35 PM
redman223's Avatar
Default Re: (greebler)
Should be able too, its an audiobahn a2801x and I have an a6801x bridged to 2ohms running my sub and it works fine.
pbizzlegsr
Audio / Security / Video
Jun 28, 2007 08:00 PM
shutta
Jan 4, 2006 06:31 PM
GetSmoked
Mar 11, 2005 03:20 PM
schwinn
Jun 19, 2002 10:54 PM
juniordc2
Jun 5, 2002 02:22 PM
