How do i do this?
Old Apr 29, 2003 | 06:46 PM
Liquidgsr's Avatar
Default How do i do this?
How do i turn my amp into a mono amp. I hooked it up to a sub and it playes out music also not just bass. Is this bad for the sub. Is it ok to keep it like this or do i have to do something so it only sends a bass signal. Thanks
Old Apr 29, 2003 | 07:48 PM
TrblPinoy1's Avatar
Default Re: How do i do this? (Liquidgsr)
DOes the amp have a built in crossover?
Old Apr 29, 2003 | 07:49 PM
t0p_sh0tta's Avatar
You don't need a mono amp, that just means it has one channel. You need to set your crossover correctly, if you have one. Make sure that it is set to low pass, and turn the adjustment *** until it sounds good. 80hz is a good starting point.
Old Apr 29, 2003 | 09:27 PM
Liquidgsr's Avatar
Default Re: How do i do this? (t0p_sh0tta)
nope has no crossover...its a orion The Hott setup amp. It has a EQ IN and OUT and thats it. 2 channel amp. Its one of the weirdest ones i have seen but its got some power. Not even sure what the RMS or MAX is on this sucker and i don't know how to find out.
Old Apr 30, 2003 | 03:52 AM
t0p_sh0tta's Avatar
You'll need an outboard crossover or a different amp.
Old Apr 30, 2003 | 05:10 AM
TrblPinoy1's Avatar
Try getting an external crossover unless your headunit has one bulit in..
Old Apr 30, 2003 | 06:11 AM
baldylox's Avatar
amp model number....ive been around to play with some Hott Setup's....
Old Apr 30, 2003 | 07:58 AM
Liquidgsr's Avatar
it has says The Hott Set-Up 2.5 thats all i get off of it. My cousin gave it to me and I looked it up but found nothing really.
Old May 1, 2003 | 12:20 PM
o_Rage_o's Avatar
Default Re: (Liquidgsr)
something like this is a sweet deal, although it looks like **** and is passive.
http://cgi.ebay.com/ws/eBayISA...14931
24db/octave butterworth with variable slope and subsonic filter at 20hz (if this was switchable to something like 35hz for you ported sub users..it would be great)
If your going to buy a crossover, I'd personally suggest some of the older Alpine EQ's that not only offer some equalization so you can tweak the sound a little depending on the track, but also give full control of your subwoofer crossover frequency and some boost control (plus..they are active..ie, in the signal chain before the amp)
Great for budget/beginner car audio, will last, and cheap (can be had for $35-40)
-Rage
Old May 1, 2003 | 04:22 PM
nsxxtreme's Avatar
Default Re: (o_Rage_o)
I don't know rage that looks like an active filter to me. Also looks pretty easy to build.
Old May 1, 2003 | 05:15 PM
vteg's Avatar
New User
Default Re: (nsxxtreme)
Yeah, I think that is active. I was on the diyaudio forum yesterday. There was a post with schematics for building a two way active crossover. It does not look too hard.
Since I am running out of stuff to squeeze into my car, I think a nice project would be building a pair of home speakers and sub
Old May 1, 2003 | 09:53 PM
nsxxtreme's Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I think that is active. I was on the diyaudio forum yesterday. There was a post with schematics for building a two way active crossover. It does not look too hard</TD></TR></TABLE> Yes active filters are very easy to build with opamps. If you get stuck let me know.
Old May 2, 2003 | 08:04 AM
o_Rage_o's Avatar
Quote off ebay
Inputs: speaker level
Outputs: preamp level
my bad yesterday i might've missed the output preamp level...didn't realize the speaker level line ins and thought they were for after the amp.
i'm a dyslexic brown guy leave me alone! :D
-Shane
KingJeff
Audio / Security / Video
May 12, 2008 08:10 AM
mmajedi
Nov 5, 2007 08:45 AM
ilikeric3
30
Sep 2, 2006 02:21 PM
VietFoo
Dec 25, 2005 12:03 AM
redteg1
Apr 9, 2002 08:46 PM
