Help - cutting out
Old Sep 29, 2003 | 12:11 PM
joek84's Avatar
Default Help - cutting out
Aight i've got a rockford 600a4 powering my 3 way focal component set inside and a autotek 400w wired at 3ohm for my audiobahn aluminum 10. My problem is that when im driving on the highway with my music up my inside speakers cut out but the bass keeps thumping. I jsut turn it down or off for 25 or so secs and it comes back on. Does anyone know how i can fix this, a 1 fared cap maybe? any help is appreciated thanks
Old Sep 29, 2003 | 12:49 PM
PetroGuyX's Avatar
it sounds like your 600a4 is going into protection and/or overheating, i'd adjust the gain on that biznitch and see if it still does it, and how long is the radio being played before it does it?
Old Sep 29, 2003 | 02:38 PM
KingOcellular's Avatar
Default Re: Help - cutting out (joek84)
If it is a 4 ohm mono (2 ohm stereo) stable amp and you have it bridged then your running at to low of an impendance and over heating the amp (not familar with that model amp). You would need a 4 ohm sub in that case.
Old Sep 29, 2003 | 02:45 PM
Default Re: Help - cutting out (KingOcellular)
OK, nevermind that. Read it, posted later, forgot it was the inside speakers and not the sub lol
Old Sep 29, 2003 | 02:46 PM
If you have a blown speaker or a grouned wire that could cause that problem also.
Old Sep 29, 2003 | 02:54 PM
joek84's Avatar
what's the gain do? When im driving around and blasting my music it'll cut out after maybe 10 mins, then i turn it down some. On the highway it happens faster the louder i have the volume as well.
Old Sep 29, 2003 | 05:17 PM
PetroGuyX's Avatar
yea, your amp is definitely overheating, the gain is the adjustment **** on the amp, controls how much power is coming out of it, you'll see a little **** on your amp, i'd say turn it down, if it's over 3/4s of the way up, that's too much
pinks11
Audio / Security / Video
Nov 19, 2007 07:04 AM
martyball619
Aug 8, 2007 03:41 PM
r1ch1e
Apr 12, 2007 09:56 AM
RobertM
Jan 9, 2006 01:05 PM
Feuerraeder
Dec 24, 2002 09:06 AM
