Heandunit problems!
Old Oct 1, 2006 | 09:49 PM
GFurm's Avatar
Default Heandunit problems!
as i was unplugging my ecu there was a small spark uner my dash by the glove box. other then scaring the crap out of me i didnt think it did anything. however, now my radio will not turn on. i have a pioneer headunit and thought i blew its fuse i took it out fuse was fine. i took appart my dash and found that the retard who owned the car before me rigged it up to the stock radio headunit which was hidden on the floor behind my cub holder (96 civ. coupe). i also noticed that my car remote does not lock and unlock my doors. is the stock HU fried? why does nothing work? the pioneer HU wiring harness was spliced into the stock harness. it was not a jumper harness.
Old Oct 1, 2006 | 10:16 PM
dc24me's Avatar
Default Re: Heandunit problems! (GFurm)
in the 96-98 civics with the factory keyless entry, the circuitry for it and the domelights are built into the radio. if they just used a regular honda harness, they needed to keep the oem deck in there for the stuff to work to get around it, unless you get a 70-1720T harness from metra that will allow you to keep the factory keyless and the dome lights.
Old Oct 1, 2006 | 10:56 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">in the 96-98 civics with the factory keyless entry, the circuitry for it and the domelights are built into the radio. if they just used a regular honda harness, they needed to keep the oem deck in there for the stuff to work to get around it, unless you get a 70-1720T harness from metra that will allow you to keep the factory keyless and the dome lights. </TD></TR></TABLE> Well almost, the Metra 70-1720T harness is the one you use when keeping the stock HU in the car, the 70-1720 harness is the one you use when you do not want the keep the stock HU in the car, you must have the stock HU in the car for the oem key-less entry and dome light supervision to work, it sounds like your saying just by having the Metra 70-1720T harness you can have the key-less and dome...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">unless you get a 70-1720T harness from metra that will allow you to keep the factory keyless and the dome lights. </TD></TR></TABLE> also you do not need any harness to keep the stock HU behind the dash, you just have to disconnect the speaker leads and connect them to the aftermarket HUs speaker outputs, parallel the acc., constant 12V+ and ground. done deal, the T harness just makes it easier and cleaner.
But if you do not want to keep the Stock HU plugged in behind the dash, you will need to install a jumper and harness like this... http://www.scosche.com/scosche...HAK3B
or hard wire the aftermarket HU harness, make your own jumper, or cut the two leads and connect them together.
That just leaves the key-less entry, you will need another R/F unit, any alarm system will do. 94
Old Oct 2, 2006 | 07:24 PM
GFurm's Avatar
i was looking at the scoche harness, how exactly does it work. the second dark gray plug from your link has no wires. does it just trip a few wires within the second connector to allow domes and keyless? cant i do that myself? i have a harness which is spliced into my stock harness then goes to my pioneer hu. can i use that one and figure out a way to trip the second connector?
also, with the description i gave does it mean my stock hu took a **** and if i simply replace it all is well again? this blows
Modified by GFurm at 9:07 PM 10/2/2006
Old Oct 3, 2006 | 09:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: (GFurm)
The small plug has a jumper lead so when plugged in it connects the dome light input and output leads together, normally done in the stock HU.
If the stock HU is mounted behind the dash and still plugged in and door-locks and dome light still do not work, then yes you have a problem with the HU, and replacing it will solve the problem, however, it's a lot easier to just install the jumper, [dome light will work] and an aftermarket alarm or key-less entry for the door locks. 94
Old Oct 3, 2006 | 05:24 PM
GFurm's Avatar
are there any diagrams where i can see where the dome light input and outputs are and does that plug also jump the keyless connectors...sorry for the questions im just determined that i can fix this problem with five minutes of wiring for free instead of ordering a $20 harness and then having to install aftermarket keyless.
Old Oct 4, 2006 | 02:46 PM
fcm's Avatar
fcm
Old Fart
Default Re: (GFurm)
The jumper will only allow the dome light to work, not the key-less, for the key-less you will need the stock HU or an aftermarket R/F section, like an aftermarket key-less entry or alarm/starter system, the stock R/F section, [the "part" that gets the signal from the factory remote control] is built into the stock HU, and it would have to be installed like this... http://www.installdr.com/Insta...3.pdf
Although not needed this is the harness will make the job a lot easier... http://www.scosche.com/scosche...HA07B
otherwise, you are going to need to cut and extend leads. 94
Old Oct 4, 2006 | 05:06 PM
xEJFDMx's Avatar
did you check the fuse?
Old Oct 4, 2006 | 05:17 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Heandunit problems! (xEJFDMx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEJFDMx &raquo;</TD></TR><TR><TD CLASS="quote">did you check the fuse? </TD></TR></TABLE>
ditto that. Did you check all fuses. Is the clock working? Check the fuse under he hood. 7.5 If I remember correctly. Hell change all the blown fuses. There are two for the radio. If all that fails take fcm advive
Old Oct 4, 2006 | 08:26 PM
GFurm's Avatar
yea checked all the damn fuses that was my first thought as well...this sux i havent had tunes in my ride for like a week now...i dont have time to mess with it...you gotta see the wire job this guy did...maybe ill take it appart tomoro and post up some pics...there is a harness spliced into a harness spliced into like 3 more harnesses its rediculous...
Old Oct 5, 2006 | 11:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: (GFurm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GFurm &raquo;</TD></TR><TR><TD CLASS="quote">there is a harness spliced into a harness spliced into like 3 more harnesses its rediculous...</TD></TR></TABLE> If that's the case then a rewire is the best coarse. 94
Old Oct 5, 2006 | 01:49 PM
97civicB18C's Avatar
Default Re: (fcm)
i agree and you should to because FCM knows his car stuff i tell you he helped me out so much
Old Oct 5, 2006 | 08:52 PM
GFurm's Avatar
thanx for all the advice, i appreciate it...
Old Oct 6, 2006 | 09:44 PM
xEJFDMx's Avatar
Default Re: (GFurm)
i USED TO DO INSTALLS FOR A MAJOR RETAIL chain....forgot had caps on...anyway...hit me up with what ya got...pics etc etc I can probably figure this out for ya!
Old Oct 8, 2006 | 08:59 PM
GFurm's Avatar
that sounds ******* awsome xEJ...ill have them for you as soon as i get a free moment...
tdizz07
Jan 11, 2010 04:58 AM
crazy_joe
Audio / Security / Video
Oct 24, 2008 08:53 AM
fortymcpants
Aug 2, 2008 01:10 PM
T_bones
Jun 19, 2007 05:08 PM
OldSkoolCiv
13
Oct 3, 2004 09:03 PM
