got a bazooka powered sub today
Old Feb 17, 2008 | 04:43 PM
TypeRobert's Avatar
Default got a bazooka powered sub today
so I bought a bazooka powered sub today cs series its a 8" 50watts
It suggest that I wire them up together with the rear speakers, but it also has RCA inputs, it will be easier for me to use the RCA
will the results be that much worse?
Old Feb 17, 2008 | 05:21 PM
B18C_EJ8's Avatar
It will sound better if you use RCA's.
Old Feb 17, 2008 | 06:16 PM
ek-g6's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">It will sound better if you use RCA's.</TD></TR></TABLE>
x2
Old Feb 17, 2008 | 07:44 PM
TypeRobert's Avatar
Default Re: (ek-g6)
alright then RCAs it is, does anyone know what kind of sound to expect from this? I have stock speakers and a pioneer HU
Old Feb 18, 2008 | 02:30 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (TypeRobert)
depends on what kind of car
Old Feb 18, 2008 | 07:17 AM
TypeRobert's Avatar
Default Re: (wrx-killer-Sti-eater)
its a camry, dont expect much of it but hope it doesnt sound like **** either
Old Feb 18, 2008 | 10:17 AM
TightEyez's Avatar
how much did you pay for it?
Old Feb 18, 2008 | 04:48 PM
TypeRobert's Avatar
Default Re: (TightEyez)
I gave the dude $50 for it, came with the original hold down straps and instructions manual, only thing im waiting for now is the amp kit, how do I know what size fuse to put in the power wire?
Old Feb 18, 2008 | 05:45 PM
sde780's Avatar
I have a 30 amp one in mine, it's 250 RMS so should be about the same as yours
Old Feb 18, 2008 | 06:08 PM
TypeRobert's Avatar
Default Re: (sde780)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sde780 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 30 amp one in mine, it's 250 RMS so should be about the same as yours</TD></TR></TABLE>
you have the same sub? the only thing the owners manual mentions is something bout not changing the included 7.5a fuse but it doesnt have a fuse holder in the harness, but it does mention this in the part of how to set up the power wire so i was thinking maybe thats what I should put in there?
Old Feb 19, 2008 | 09:28 AM
ek-g6's Avatar
yeah put the 30a fuse on there, but on the amp it self. How are the speakers in your car right now? are they blown, ripped, or torn? if you like how your stock speakers sound, your bazooka sub will make your car have a bit more bass. but it should sound good, regardless of your other speakers, unless the bazooka sub is messed up some how.
Old Feb 19, 2008 | 09:39 AM
TypeRobert's Avatar
Default Re: (ek-g6)
stock speaker in there are good right now, still want a definite answer on the fuse to put in there...I cant find the RMS specs for the sub, and the book mentions a 7.5a which is very big deifference from 30-40a
Old Feb 19, 2008 | 09:49 AM
ek-g6's Avatar
well if the manual says 7.5a, use that, dont get a bigger fuse, because if you have a short, the the fuse wont blow until it reaches that 30a fuse blowing rating, but by that time your amp, and maybe sub will already be fried. I think you have the 50watts bazooka, and they dont need no 30a fuse, stick with the 7.5a, it will work just fine.
Old Feb 19, 2008 | 10:02 AM
TypeRobert's Avatar
Default Re: (ek-g6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-g6 &raquo;</TD></TR><TR><TD CLASS="quote">well if the manual says 7.5a, use that, dont get a bigger fuse, because if you have a short, the the fuse wont blow until it reaches that 30a fuse blowing rating, but by that time your amp, and maybe sub will already be fried. I think you have the 50watts bazooka, and they dont need no 30a fuse, stick with the 7.5a, it will work just fine. </TD></TR></TABLE>
ook just though maybe 7.5amps was too little and yea it is the 50watt bazooka,
I went looking for a 7.5a agu fuse could only find 7a and 8a on radioshack, go with the 8a?
Old Feb 19, 2008 | 10:12 AM
ek-g6's Avatar
you could just buy the inline fuse holder from radioshack, and buy the 7.5a fuse from somewhere else. if you dont want to do that, then just take 8a it'll do the same.
Old Feb 19, 2008 | 05:53 PM
sde780's Avatar
Default Re: (ek-g6)
didn't see the 50 watts part, I thought he had the one with 500 watts max and 250 rms
Old Feb 19, 2008 | 06:20 PM
TypeRobert's Avatar
Just waiting on my amp kit and HU to arrive
my amp kit comes with a 40a fuse so im going to have to go find a 7.5a one
I also wanted to put a switch on my remote wire in case I wanted to turn it off, any switch would do right no big deal on the remote wire?
Old Feb 19, 2008 | 06:55 PM
ek-g6's Avatar
yeah you can put a switch on it no problem
bombers_2007integra
Audio / Security / Video
Oct 17, 2006 08:13 PM
tca0bell
Nov 15, 2004 07:18 PM
pezzy
Aug 27, 2004 07:09 AM
im_the_teacher
Jan 19, 2004 04:08 PM
fluke702
Jan 25, 2003 10:21 AM
