headunit amp
Old Aug 26, 2004 | 10:55 PM
pezzy's Avatar
Default headunit amp
i have an aiwa headunit and it says it pushes 45 watts x 4 channels... i also have an amp thats only 2 way that i use for my alpine sub. but my amp is dieing...
im going to get 4 new speakers because they are all popped.
i intend to get speakers that have 50 continuous watt power..and wire it through the headunit..
therefore do i need a 4 way amp? or will a 2 way work fine?
Old Aug 27, 2004 | 07:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: headunit amp (pezzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pezzy &raquo;</TD></TR><TR><TD CLASS="quote">i have an aiwa headunit and it says it pushes 45 watts x 4 channels... i also have an amp thats only 2 way that i use for my alpine sub. but my amp is dieing...
therefore do i need a 4 way amp? or will a 2 way work fine?</TD></TR></TABLE> the Aiwa HUs
45x4 is peak power, it is less than 20x4 RMS, if you are going to relpace all 4 speakers with ones that will handle 50watts continuous, then a 4x50watt [RMS] amp is a good idea, and replace the sub amp with a 200 to 300 watt [RMS] mono sub amp, If low on $ get the 4ch amp and use 2ch to drive the front speakers on highpass and use the other 2ch [bridged] to drive the sub, use the rear speaker outputs of the HU to drive the rear the speakers, then when you can afford the $ get the sub amp for the sub and rewire the 4ch to the rear speakers. 94
superdat1
Audio / Security / Video
13
Jan 4, 2008 10:42 AM
pezzy
Aug 28, 2004 09:20 PM
shyboy817
Aug 12, 2004 11:30 PM
technine
15
Jun 15, 2004 08:04 AM
FatJoe
Oct 5, 2003 10:12 AM
