fuel pump kill switch problem...
Old Aug 22, 2003 | 07:45 AM
theman-dlh's Avatar
Default fuel pump kill switch problem...
have a fuel pump switch currently installed in my car, but I have to replace it about every month and a half. I was just wondering if you guys knew what I'm doing wrong? I'm using 20amp switches. they seem to get really hot then melt, but they stay really cool, and seem to be okay up until the switch goes out? All I can think of is that it might be poor quality switches.
Thanks guys.
Old Aug 22, 2003 | 03:32 PM
Ziggie's Avatar
Default Re: fuel pump kill switch problem... (theman-dlh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theman-dlh &raquo;</TD></TR><TR><TD CLASS="quote"> have a fuel pump switch currently installed in my car, but I have to replace it about every month and a half. I was just wondering if you guys knew what I'm doing wrong? I'm using 20amp switches. they seem to get really hot then melt, but they stay really cool, and seem to be okay up until the switch goes out? All I can think of is that it might be poor quality switches.
Thanks guys. </TD></TR></TABLE>
Try using different switches. Maybe higher than 20amps??????
Old Aug 22, 2003 | 06:08 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: fuel pump kill switch problem... (Ziggie)
If they're getting hot, it's because the amount of current needing to draw is being restricted. Usually its something like maybe a thin wire, bad contacts, or a bad ground.
Like on an amplifier setup with too thin of a power cable but a really high amperage fuse, will probably melt the fuse holder area.
Same thing.
Old Aug 22, 2003 | 08:02 PM
SpeedDreamz.com's Avatar
Use the switch to operate a spst or spdt relay. That way the relay carries the current not the switch. They are rated at 40 amps.
Old Aug 22, 2003 | 09:51 PM
theman-dlh's Avatar
I don't have a relay, so I should get one of those then try it?
Old Aug 22, 2003 | 11:32 PM
99teggsr's Avatar
There is a much easier way to do this. Look under the dash on the drivers side for a grey box. This is the main relay which controls the ECU, Fuel pump, and other things. Cut the black ground wire and add in a switch. I did this to my integra and the switch and wiring has not burnt out and its been over 8 months. I will try and get pics if you cant find it.
Old Aug 23, 2003 | 06:33 AM
Default Re: (99teggsr)
I dont think I would suggest disconnecting the ground from any electronics. All electronics need a ground to operate correctly. If you disconnect the ground,even through a switch, then when the switch is off the unit will look for another circuit to ground through. MIght be the ign control, abs, or even the cluster bulbs.
Old Aug 23, 2003 | 06:35 AM
VTECorona's Avatar
Default Re: (30psiCiv)
See https://honda-tech.com/zerothread?id=592205
Old Nov 1, 2003 | 08:48 AM
theman-dlh's Avatar
Default Re: fuel pump kill switch problem... (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">If they're getting hot, it's because the amount of current needing to draw is being restricted. Usually its something like maybe a thin wire, bad contacts, or a bad ground.
Same thing.</TD></TR></TABLE>
I just wanted to say thanks for the help, I replace the wire fore some thicker wire and I have had no problems with it for about 2 months, were before I was replacing the switch about every 3 weeks.
The wire I was using was the same size as stock but, I ran more than 2 feet off of were I split the wire. Thanks again guys
Tapout383
Dec 1, 2009 05:09 PM
hondamoonchucks
12
May 26, 2006 12:13 AM
Mgsr
Jun 24, 2005 10:51 AM
adictionbass
Audio / Security / Video
11
Jan 28, 2005 06:49 AM
