fuel cut off switch.
Old Jan 26, 2005 | 06:09 PM
adictionbass's Avatar
Default fuel cut off switch.
Alright so ive searched and found alot of info, but nothing on my, what seems to be, too simple idea.
Is it okay, and safe, to just put a rocker switch inline of the fuel pump ground? Basically just use the switch to interrupt the ground so the pump obviously wont work.
It seems like everyone is thinking too hard about this.
TIA, josh
Old Jan 26, 2005 | 07:46 PM
Default Re: fuel cut off switch. (adictionbass)
Old Jan 27, 2005 | 07:37 AM
well, im going to be doing this today probably. anyone know if im going to blow myslef up
Old Jan 27, 2005 | 07:49 AM
The Alchemist...
Guest
Posts: n/a
I need to do one also - what guide are you using?
Old Jan 27, 2005 | 07:55 AM
Default Re: fuel cut off switch. (w-a-o)
i was planning on using the, grab the helms, find the ground for the pump, and put a rocker switch inline. But none has responded to how this would work. It seems like people are going crazy with relays and such for something so simple.
Old Jan 27, 2005 | 07:57 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">well, im going to be doing this today probably. anyone know if im going to blow myslef up </TD></TR></TABLE> Why would you not want to do it on the fuelpump power wire? The problem with cutting the ground to anything is ground is common, and a load will try to find a ground through another path, and that can be a problem, I don't think your going to blow yourself up, but an electric device submerged in a tank of gas with 12v+ going in and no ground 94
Old Jan 27, 2005 | 07:58 AM
The Alchemist...
Guest
Posts: n/a
Default Re: fuel cut off switch. (fcm)
http://www.courtlukens.com/Tech/cutoff_switch.htm
This guy has an easy looking write up.
Judging from this write up all you need to do is locate the YELLOW wire with a GREEN stripe and put a SPST switch in between it. Seriously looks like the hardest thing is removing the rear seat.
Old Jan 27, 2005 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Why would you not want to do it on the fuelpump power wire? The problem with cutting the ground to anything is ground is common, and a load will try to find a ground through another path, and that can be a problem, I don't think your going to blow yourself up, but an electric device submerged in a tank of gas with 12v+ going in and no ground 94</TD></TR></TABLE>
the reply i was looking for
Old Jan 27, 2005 | 08:05 AM
The Alchemist...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">i was planning on using the, grab the helms, find the ground for the pump, and put a rocker switch inline. But none has responded to how this would work. It seems like people are going crazy with relays and such for something so simple.</TD></TR></TABLE>
I have also seen the ones using relays – I don’t see really why that is necessary. It is not going to slow a thief down. I think I am going to do the same basic set up as the link I posted.
"The wiring for the pump runs along the driver's side door sill." &lt;---
I would like to think if you put one of these in and hide it well along with a good alarm you can stop most thieves. Then again most people who steal cars know what to expect – that is why doing stuff to confuse them helps. A guy would rather steal a car that has a basic alarm then one with a full cut off and an alarm that has interior sirens.
Old Jan 27, 2005 | 03:02 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w-a-o &raquo;</TD></TR><TR><TD CLASS="quote">I have also seen the ones using relays – I don’t see really why that is necessary. It is not going to slow a thief down. I think I am going to do the same basic set up as the link I posted.
I would like to think if you put one of these in and hide it well along with a good alarm you can stop most thieves. Then again most people who steal cars know what to expect – that is why doing stuff to confuse them helps. A guy would rather steal a car that has a basic alarm then one with a full cut off and an alarm that has interior sirens. </TD></TR></TABLE>
Relays have nothing to do with the security. They are there to ensure that the fuel pump gets the proper current/voltage since the power has to pass through the switch now which has some resistance to it.
Security only buys time. If a theif wants something they will get it.
Old Jan 27, 2005 | 09:48 PM
sdinteg's Avatar
Default Re: fuel cut off switch. (chowmien)
Relays also allow one to use a smaller switch since the current will be flowing through the relay terminals, not the switch itself
Old Jan 28, 2005 | 06:49 AM
fcm's Avatar
fcm
Old Fart
Default Re: fuel cut off switch. (sdinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdinteg &raquo;</TD></TR><TR><TD CLASS="quote">Relays also allow one to use a smaller switch since the current will be flowing through the relay terminals, not the switch itself </TD></TR></TABLE>Ditto that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">
Relays have nothing to do with the security. They are there to ensure that the fuel pump gets the proper current/voltage since the power has to pass through the switch now which has some resistance to it.</TD></TR></TABLE>LOL..... Relays have nothing to do with security? How about starter cut relay, or ign. kill relay. any switch has "some resistance to it" a relay is just a switch 94
EJ8 GSR-T
Audio / Security / Video
Dec 25, 2006 06:46 PM
Felliph3
Oct 8, 2006 08:25 AM
Mgsr
Jun 24, 2005 10:51 AM
theman-dlh
Nov 1, 2003 08:48 AM
Quick Silver
Jan 6, 2003 08:30 AM
