ELECTRONIC ISSUEE IN A EG!!
Old Feb 23, 2010 | 12:54 PM
nano1589's Avatar
Icon2 ELECTRONIC ISSUEE IN A EG!!
I hope someone can help me out!! okk.. everything stared when i changed the EX cluster into a DX. (TACH into notach) The DX cluster has 4 back plugs (2 grays 1 yellow and 1 green) same with the EX but the GREEN plug is different. so what i (idiot) did, i cuted the plugs and swaped them. I didnt notice that the green plug of the DX comes with 9 wires which is for the shift ligth (P R N D 2 1) on the cluster. So i taped the EX plug to the same wires colors and left some to the side and turn the car on. Now my problem is that when i turn the parking and headligth on the cluster ligth goes off and the gauges down and shows the hazard and high beam on but if i pull the hand brake until it turns its light everything works perfect. Neither the wipers and the heather is working.
Old Feb 24, 2010 | 05:53 PM
nano1589's Avatar
Default Re: ELECTRONIC ISSUEE IN A EG!!
Does any one know wheres the integrated control unit is located it in a civic 93?
Old Feb 25, 2010 | 05:43 AM
fcm's Avatar
fcm
Old Fart
The ICU is mounted to the back of the under dash fuse box. 94
Old Feb 25, 2010 | 12:57 PM
nano1589's Avatar
Yeah!! Thanks!! I looked up in the 92-95 civic book and i found that all that is running bad comes out of the ICU and when i turn on the ligths the brow box in the back of the fuse box makes a rare sound! I changed it for the ex ICU but it keeps doing it! =[ does it have any diff with the auto and manual icu!?
Old Feb 25, 2010 | 02:25 PM
fcm's Avatar
fcm
Old Fart
The ICU does not control the heater or head lights, it does control the front side markers, [signal/hazard/park light].
The ICU only controls intermittent wipers.
It sounds like you have a grounding problem at the cluster. 94
Old Feb 25, 2010 | 03:41 PM
nano1589's Avatar
The headlights are good, the side markers wont work if i take the hand brake off. I will take the cluster off and check again for any cuted wire or something. Thanks for your help!!! This is driving me crazyy!!
Old Feb 26, 2010 | 06:30 PM
wes7side5o's Avatar
wow from my past experience I thought they were plug and play clusters. If you going from auto to stick you just leave plugs that don't fit unplugged. They are for the P R N D L 2 lights which is not needed n e more.
Old Feb 27, 2010 | 11:59 AM
nano1589's Avatar
I found a ground plug unpluged!! That was the problem! The wipers the heater and the lights works perfect! Your the man!! Thanks a lot for your help i really appreciated!! =]
yankeefan855
May 15, 2010 03:55 PM
eG6haTchY
Aug 12, 2008 04:32 PM
Nickboxer7
17
Apr 28, 2008 09:24 AM
SoOHiGH
25
Aug 3, 2005 12:00 PM
89 EF Si
Mar 14, 2005 08:53 AM
