Easy Integra Audio/Speaker Question
Old Sep 17, 2002 | 11:48 PM
SmokeU's Avatar
Default Easy Integra Audio/Speaker Question
What size are the speakers in a G3 Integra?
I would like to replace the speakers since I have a new head unit and it sounds better.
I don't want a "system" I just want new speakers since the car is a 95, I just need to know what size the speakers are.
Old Sep 17, 2002 | 11:53 PM
97teg415's Avatar
Default Re: Easy Integra Audio/Speaker Question (You Know Me)
Ive got a 97 integra and i have 6 1/2's in the front and the back seats.
Old Sep 18, 2002 | 12:50 AM
Anthony K's Avatar
New User
Default Re: Easy Integra Audio/Speaker Question (97teg415)
I thought fronts were 5 1/4?
Old Sep 18, 2002 | 06:44 AM
TEG98's Avatar
Default Re: Easy Integra Audio/Speaker Question (Anthony K)
You can check at crutchfield.com Bwe sure to check depth and speaker protrusion. I believe that I had some problems getting speakers that would fit the openings. (pair of 6.5 from last car wouldn't fit)
Old Sep 18, 2002 | 09:44 AM
ULTiMaX99's Avatar
they're suppose to be 6.5's all around, but I had trouble installing mine. had to hack up the stock plastic mounting basket to make it fit.
you say u dont' want a "system" now... but later you're gonna want at least a sub. you just don't get enough bass from 6.5's.
Old Sep 18, 2002 | 01:04 PM
bikeboy80's Avatar
Default Re: Easy Integra Audio/Speaker Question (ULTiMaX99)
stock speakers are 5 1/4 for the doors and 6 1/2 for the rears, you can get some 6 1/2 speakers to fit in the doors with some modification, lige someone else said your best bet is to check crutchfield, btw they will also give you plugs to go into your stock harnesses if you dont want to hack away at them, good luck
Old Sep 18, 2002 | 01:30 PM
Volcom's Avatar
Default Re: Easy Integra Audio/Speaker Question (bikeboy80)
I put 6.5 in both front and rear speaker spots. Good luck getting to the rears. I have to take out the entire plastic side panel just to get to the speakers.
Old Sep 18, 2002 | 01:47 PM
B Speed's Avatar
Default Re: Easy Integra Audio/Speaker Question (Volcom)
I have Cerwin Vega 6.5's in the front, none in the rear for weight savings.
KamakuraKid
Honda Fit
Sep 24, 2007 10:46 AM
desiromeo812
Mar 19, 2005 10:36 PM
Kryptonite
Jan 13, 2004 04:31 PM
inzaneN1
Audio / Security / Video
Jun 25, 2003 09:57 PM
FrostyGSR
Dec 19, 2001 03:42 PM
