Battery relocation questions
Old Jan 23, 2012 | 07:43 AM
jadugartir's Avatar
Default Battery relocation questions
Im going to be relocating my battery in my hatch to make room for other things. I will be putting it in the trunk inside a battery box bolted to my floor, and running 0 gauge wire from my engine bay to the trunk. In the engine bay i was planning on having a power distribution block, with (1) 0 gauge input and (4) 4 gauge outputs. One going to the starter, one to the fuse box, then have 2 blank spots for future use, maybe.
Then in the back, i know i need to put a fuse several inches from the battery. My question is what size fuse do i need for a setup like this in a EG hatch, with probably 10-12 feet of 0 gauge wire. While searching i read anywhere from 80A to 150A, hence my confusion. Also my starter is a B series starter if that helps. I figured this would be a good spot to ask. Also, i know these power distribution blocks are typically for audio setups, but it seems like a nice clean way to run power under the hood. Are there any problems with this?
Old Jan 23, 2012 | 10:11 AM
hondanamics's Avatar
Default Re: Battery relocation questions
80amp is fine.
Old Jan 23, 2012 | 05:45 PM
fcm's Avatar
fcm
Old Fart
First, you do not need "0 gauge" cable, there is nothing in the car that needs 350A of current, [capacity of 1/0 cable] 2 gauge will be more then enough, use a 250A ANL fuse with a stud type fuse holder as close to batt. as possible.
Run the cable from the batt. to the starter motor, run an 8 gauge from the starter motor to the engine bay fuse box, [do not use any kind of distribution block] use proper sized ring terminals, [stud size] crimp and solder the terminals to all the cables.
Run a 2 gauge ground from the batt. to the cars floor pan, [seat belt bolts work great] keep the ground as short as possible.
Add a 2 gauge ground from the chassis to the engine, [you can replace the stock chassis to engine ground with the 2 gauge, your done. 94
Old Jan 24, 2012 | 06:45 AM
jadugartir's Avatar
Thanks, exactly what i needed.
Old Jan 25, 2012 | 08:50 AM
delsolo95's Avatar
this is what i did. except used 6 guage from fuse box to distribution block and fuse box to alternator.
Old Jan 25, 2012 | 09:14 AM
A L I A S's Avatar
Old Feb 14, 2012 | 04:44 PM
ej6civic619's Avatar
Nice really help with ur illustration bout to do this tomorrow or so how much did u spend on supplies?
Old Feb 15, 2012 | 10:58 AM
delsolo95's Avatar
battery relocation kit was about 78 bucks includes battery lugs + and -, 20 ft 2 guage +, 3 ft 2 guage -, battery tray, and terminals. bought some heavy 6 guage wire for alternator and fuse box about 20 bucks. and some terminals for 10 bucks. didnt spend more than 140.
JuneBugDrfter
Feb 26, 2013 11:49 AM
dylaxiin
May 11, 2011 07:11 PM
EFinawesomeman
Sep 23, 2008 03:57 AM
lilo_goki
Aug 22, 2008 03:46 PM
AntMan401
Feb 19, 2008 09:50 PM
