need help, doing battery relocated.
okay, i'm doing battery relocate and fuse box relocate, i was just wondering if i can just run the power wire from the battery to fuse box, and then connect it from the fuse box to the starter. will it be okay, or should i just run it separate.
Re: (lilo_goki)
im using 4 gauge without a problem. The only thing different i am doing is i have battery post mounted on my firewall and i am using them as a distribution block. So i have a cable from my battery to the back of the post, then a wire to the fuse box. The starter wire runs from the post to the starter. This set up has worked awesome for me so far.
notnic3
06-12-2017 11:26 AM
chillerice
02-20-2013 07:48 PM
jimihendrixbro
11-23-2007 10:39 PM
