Amp no work, Help
Old Nov 15, 2004 | 10:37 AM
94Accord2c's Avatar
Default Amp no work, Help
I just bought an Infinity Kappa 52a 2x 50 watt amp off ebay. He said it worked previously, but when hooked up it powers on normal but plays very quietly. Does anyone know what would cause an amp to play really quietly but when the gain is turned it crackles in the speakers really loud.
Thanks for the input.
Phill
Old Nov 15, 2004 | 06:49 PM
Auex's Avatar
Default Re: Amp no work, Help (94Accord2c)
Well it doesn't sound good. By the way you describe the sound crackling when you play with the gain makes it sound like there is something wrong inside the amp. Assuming everything is hooked up right (power ground and rcas) what could cause diminished volume, or no volume most of the time, is the speakers the amp is hooked upto are blown or the speaker wire is grounded.
Old Nov 16, 2004 | 06:01 PM
lv6l's Avatar
i had that same problem
playing quite, i plug my rca backwards
crackles, my ground wasn't a flush ground, i took off the ground wire sand down the body till i took off the paint and see metal, fix my problem right away, maybe it'll help you
Old Nov 16, 2004 | 06:22 PM
EBP_SI's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">i had that same problem
crackles, my ground wasn't a flush ground, i took off the ground wire sand down the body till i took off the paint and see metal, fix my problem right away, maybe it'll help you</TD></TR></TABLE>
jsut curious....how do you plug an RCA in backwards?
Old Nov 16, 2004 | 07:19 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Sounds like your speakers are wired to a high ohm and the amps not putting out enough power so the speakers are crackling.
That kind of speakers are you running and what ohms are they? Also are they dual or single voice coil?
Old Nov 16, 2004 | 08:47 PM
lv6l's Avatar
i plug is backwards by the color, white/red or black/red, or R/L get it?
Old Nov 17, 2004 | 12:42 PM
Auex's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">i plug is backwards by the color, white/red or black/red, or R/L get it?</TD></TR></TABLE>
Physically impossible to plug rca's in backwards. The amp doesn't care about front/back or left/right. You can wire rca's backwards but not plug them in backwards.
Old Nov 17, 2004 | 12:58 PM
nsxxtreme's Avatar
Do you get any humming noise.
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
EG-SIXV-TEC
Nov 30, 2009 08:42 AM
Stock90Civic
Mar 14, 2009 11:24 AM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
Maple50175
Apr 8, 2008 06:15 AM
