Help is my amp affected shorted????
Old Nov 29, 2009 | 11:42 AM
EG-SIXV-TEC's Avatar
Icon2 Help is my amp affected shorted????
Hi i got a question quick one.
Today i took out the neg 4 gauge wire and near the positive power wire on the amp and i accidentally made a spark on the positive terminal.
it had a little spark and made only a very small burn on the positive wire, no fuses were blown.
i dont know if its internally shorted am i safe??? i tested my amp again to max if it made power and sounds weaker or is it just my mind if it made less power???but it sounds same
just to be sure do you think my amp is affected???
Old Nov 30, 2009 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Default Re: Help is my amp affected shorted????
Amp should not have been affected as the short was before the amp.
However, if amp was on at the time you disconnected the ground the signal returns, [signal grounds] can be damaged, normally in the HU, as the amp will get it's ground from wherever possible, so if the amps ground is removed all that is left is the signal grounds through the RCA cable. 94
Old Nov 30, 2009 | 08:42 AM
thanks i was worried at the time, anyway if thats the cause so its just the signal grounds through RCA cable to look for? if there good i dont have to worry then? thanks...
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
Stock90Civic
Mar 14, 2009 11:24 AM
boostedjdmdc2
Feb 23, 2009 05:08 PM
94 SIR
Dec 5, 2008 12:50 PM
brickonwheels
Jan 12, 2004 09:33 PM
