amp install? help!
Old Sep 10, 2003 | 07:01 PM
Shadow Racer's Avatar
Default amp install? help!
i need help on hooking up an amp to my 98 integra. i dont know anything about audio. please help.
Old Sep 10, 2003 | 11:44 PM
redazn72's Avatar
are you amping highs or subs?
Old Sep 11, 2003 | 07:41 PM
Default Re: (redazn72)
its a seperate speaker from my system,not sure what it is its my friends. i need help on the wiring. any help is appreciated.
Old Sep 11, 2003 | 07:51 PM
5lugNinja's Avatar
Default Re: (Shadow Racer)
positive - red - from battery to amp
negative - black or dark brown - to ground
remote- blue- to head unit
input-rca's- from head unit (if there lows)
output negative/positive to speaker
Old Sep 11, 2003 | 08:00 PM
VTECorona's Avatar
Default Re: (SpinningDUBs)
You're going to have to take off some panels to get it to look clean.
Run a power wire from your battery to your amp location (4-10 guage will be ok depending on size of amp and distance ran). You will also need to run a remote turn-on wire and a set of RCA cables. The remote turn-on can either be connected to your stereo's remote turn-on lead or if it doesnt have that hook it up to the power antenna lead. For the RCA's it's kinda self-explanatory. Last but not least just connect speaker wires to the amp to the speaker and your set. Make sure to put an inline fuse on your (+) lead to the battery.
Old Sep 14, 2003 | 07:26 AM
PetroGuyX's Avatar
did you have any SPECIFIC questions?
Old Sep 14, 2003 | 08:04 PM
Default Re: (VTECorona)
thanks for the advice but which wires are which on the head unit. thats the confuusiong part for me.
Old Sep 15, 2003 | 07:03 AM
Jagan'92's Avatar
you have a factory head unit? the manual will have the wiring diagram, or someone on here. or you can pull it and sometimes there is a sticker on top of the unit giving the wiring scheme. but if you're just installing an amp - the speaker wires are already back there with the speakers. i mean, just clip into them at the speakers and run the wires to the amp. then run the output wires from the amp to your new speaker.
the hardest part is getting that big power cable from the battery to the amp, and getting a remote wire from the head unit (or cigarette lighter or something else that switches how you want it) back to the amp as well.
Old Sep 15, 2003 | 05:58 PM
Default Re: (Jagan'92)
thanks! thats exactly what i did. but i didnt read your message until after. now all i have to worry about is the remote turn on. but that will be easy. thanks everybody!
Old Sep 16, 2003 | 09:45 PM
ATF Kuk's Avatar
ur right next to me, im always in pasadena. ill help u install it. lets set up something
Old Sep 17, 2003 | 06:48 PM
Default Re: (ATF Kuk)
thanks but i already hooked it up ghetto style. didnt have money so i just wired it to one of the rear speakers. all i have left is the remote switch so i dont have to keep unplugging it from my battery when ever i park. also i need to mount the head unit cuz the clips are missing. thanks anyway though. what are vouches for?
Stock90Civic
Audio / Security / Video
Mar 14, 2009 11:24 AM
TheUAccord23
Jan 2, 2008 11:56 PM
XViEtBoiX
Jan 21, 2004 05:36 PM
h2392si
Oct 24, 2003 09:54 PM
Accord15
10
Nov 30, 2001 09:44 PM
