Help on install of system
Old Dec 30, 2007 | 08:04 PM
TheUAccord23's Avatar
Default Help on install of system
Hopefully someone can help a noob out. I want to get a head unit, but it only has 2 pairs of preamp outputs. I'm hoping to connect a pair of components in the front (connected to a 2 channel amp), a pair of 6x9s in the back (no amp) and a pair of subs (connected to a 2 channel amp). Question is, is it possible to connect everything with only 2 outputs? If so, can someone tell me how? A diagram, if not asking for too much, would really help me out. Thanks
Old Dec 31, 2007 | 12:45 AM
8520's Avatar
Default Re: Help on install of system (TheUAccord23)
Yes.
The front rca outputs will get to the 2 channel front amp; the rear/sub rca's will go to the sub amp. The rear speakers will be powered like stock, off deck power.
Old Dec 31, 2007 | 12:54 PM
Default Re: Help on install of system (8520)
thanks for the help 8520
Old Jan 2, 2008 | 11:56 PM
dynimitejack's Avatar
If you are purchasing a 2 ch you might as well get a 4ch and hook up all speakers you will be much more satisfied all you have to do is buy 2 RCA y connectors to run 4 ch RCAs or you could still run 2 ch.
digital sol
Audio / Security / Video
Jul 8, 2013 09:20 AM
rutherfordhigh
Nov 22, 2008 03:38 PM
krnsamiam
Sep 11, 2006 06:33 PM
gsr civic dx
Apr 18, 2005 11:20 AM
XViEtBoiX
Jan 21, 2004 05:36 PM
