adding rear speakers
Old Jul 13, 2004 | 03:47 PM
azndragon328's Avatar
Default adding rear speakers
i have a 92' civic, i have a jvc 180 watt haedunit, stock front speaker, i currently want to replace the front speakers to something better and add rear speakers at the same time, there is current;y no rear speakers, do i need to run wire or anything, what do i need just 4 new speakers? do i need an amp?
thanks, Kevin
Old Jul 13, 2004 | 06:24 PM
nemesismachine's Avatar
Default Re: adding rear speakers (azndragon328)
you need to replace the stock front ones, they suck and cant be amplified. get 2 sets of alpine R1 6 1/2" components. one set for the front, the other for the back. with a little fiberglass work, you can make the back ones work out. Thats what i did. all the wires run from the amp to each speaker (provided you have a 4 channel amp). it'll take about an afternoon to finish, but will be well worth it when youre done.
Old Jul 14, 2004 | 11:38 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azndragon328 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92' civic, i have a jvc 180 watt haedunit, stock front speaker, i currently want to replace the front speakers to something better and add rear speakers at the same time, there is current;y no rear speakers, do i need to run wire or anything, what do i need just 4 new speakers? do i need an amp?
thanks, Kevin</TD></TR></TABLE>
what i would do if i were in your shoes is get the front spreakers and instead of getting rears get an amp for the fronts. the end result is much much better.
Old Jul 14, 2004 | 05:42 PM
Hondaaccordvtec's Avatar
Default Re: adding rear speakers (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
what i would do if i were in your shoes is get the front spreakers and instead of getting rears get an amp for the fronts. the end result is much much better. </TD></TR></TABLE>
I agree, but get a 4 channel amp so that you can bridge two of them to run a small sub
Old Jul 14, 2004 | 07:22 PM
fcm's Avatar
fcm
Old Fart
Rear speaker leads are already run on all Hondas.
508_honda
Audio / Security / Video
May 18, 2016 09:39 AM
CoolRedXylophone
Aug 28, 2007 08:37 AM
R4ND0M
35
Dec 22, 2006 07:21 PM
pjz99accord
Aug 19, 2006 08:48 AM
losssoul
Mar 9, 2004 06:01 PM
