How many amp do i need??????
Old Mar 8, 2004 | 09:24 PM
losssoul's Avatar
Default How many amp do i need??????
Supps guys,
I wondering how many amps do u need to run a 1 pair of 6x9 (rear), 1 pair 6" (rear), 2 10inch subs (rear), 1 pair 61/2" (front), 1 pair of tweeters (front) and 1 4" speaker (front).
Thanks in advance guys.
Old Mar 8, 2004 | 09:30 PM
rcurley55's Avatar
New User
Default Re: How many amp do i need?????? (losssoul)
I'll tell you right now - you have WAAAAAYYYYYY too many speakers....
Old Mar 8, 2004 | 11:34 PM
dmbmalaka's Avatar
Why so many speakers?
Lose the back 6" speakers and get a nice component system for the front, then run the interior speakers with one amp (200x4 should do), then get 1 amp for the rear subs (500x2 wouldn't be too bad). Make sure you have two sets of preouts first from your HU. This setup would sound nice IMO, but who cares about that .
Old Mar 9, 2004 | 02:13 AM
Xsi's Avatar
Xsi
Default Re: How many amp do i need?????? (fordSuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fordSuck &raquo;</TD></TR><TR><TD CLASS="quote">Why so many speakers?
Lose the back 6" speakers and get a nice component system for the front, then run the interior speakers with one amp (200x4 should do), then get 1 amp for the rear subs (500x2 wouldn't be too bad). Make sure you have two sets of preouts first from your HU. This setup would sound nice IMO, but who cares about that .</TD></TR></TABLE>
Agreed
If I were you I'd ditch the 6 x 9's straight away and probably the rear 6 inchers as well. It's not all bad to have those 6 speakers in the front if you want to spend time tuning but you may want something simpler like a nice set of speaker/tweeter components or just lose the 4 inch speakers.
Either way I'd suggest 2 amps, one to supply plenty of power to the fronts and the other for the subs. If you really want to keep the rears you could just run them off the headunit.
Old Mar 9, 2004 | 10:30 AM
Boxcar's Avatar
STOP!!!!!!!!!!!!!!!!!!!!!! set of good compinets and a good sub is all anyone needs
u can get a 3ch or a 5ch have one amp to do everthing
Old Mar 9, 2004 | 02:07 PM
losssoul's Avatar
Thanks guy,
My car use to be a competition car from the pervious owner, that's why there are so many dam speaker hole.
Old Mar 9, 2004 | 03:08 PM
Xsi's Avatar
Xsi
You could make do with one amp, might not give enough power to your subs so you might want two.
Old Mar 9, 2004 | 04:37 PM
snoochtodanooch's Avatar
Default Re: (losssoul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by losssoul &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guy,
My car use to be a competition car from the pervious owner, that's why there are so many dam speaker hole. </TD></TR></TABLE>
he probably didn't do too well then. it may have been loud, but it probably sounded like donkey crap. Ditch at least one of the rear speakers, if not both, and possibly ditch the 4" unless its in a nice spot like a kick panel or something. too many speakers will sound real bad.
Old Mar 9, 2004 | 05:50 PM
Smashback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by losssoul &raquo;</TD></TR><TR><TD CLASS="quote">Supps guys,
Thanks in advance guys. </TD></TR></TABLE>
Well, if you're gonna use all those speakers, here's what I would do:
run the 6.5 and 6" from a 4 channel amp
run the 6 inch and the subs (wired in parallel if your amp can handle a 2 ohm load, that way you can bridge the two rear channels on the amp - this will give plenty of power to the subs as long as you get a decent sized amp) from the another 4 channel amp
Run the tweets and 4 inchers from the 4 channel amp on the head unit. I would suggest using appropriately sized capacitors wired in series with the pos wire of these 4 speakers to filter out lower freqs.
In short, use a 4ch, 40+watts/ch amp for the 6 and 6.5s
Then use a 4 ch, 75+ watts/ch amp for the 6x9s and subs
Use the receiver's built in amp for the 4's and tweets.
Hope this helps!
Old Mar 9, 2004 | 06:01 PM
losssoul's Avatar
thanks alot guys for the help
gizbirne
Audio / Security / Video
11
Jun 13, 2014 06:58 PM
Cody2289
14
Feb 11, 2008 09:28 AM
Pworld
Apr 29, 2005 09:14 PM
JDM_Type-R
17
Aug 18, 2004 07:02 PM
xero-cool
13
Jun 5, 2004 12:31 AM
