2 or 4 ohms?
Old Jul 10, 2005 | 09:00 PM
ill3galdr1v3r's Avatar
Default 2 or 4 ohms?
ok this may be a newb question to some, but i never understood ohms. i searched for "ohm" and found 1 result which didnt help any. i was just wondering whats the difference between 2 ohms and 4 ohms. im looking into getting alpine type r subs in 10 inch form. but i dont know which one to get. the 2 ohm or 4 ohm. i guess i just need to know what the significance of the ohms are. thanks in advance for clearing this up for me.
Old Jul 10, 2005 | 10:57 PM
LudemanDan's Avatar
Default Re: 2 or 4 ohms? (ill3galdr1v3r)
Ohms measure electrical resistance. The higher the resistance in a circuit, the more ohms.
Car speakers are almost always 4 ohms. If you wire two 4-ohm speakers in parallel, you are doubling the channels the current can take and therefore lowering the resistance, so you'll get a 2 ohm circuit. If you wire two 4-ohm speakers in series, you're setting two obstacles for the current and you'll get an 8-ohm circuit.
Subs are either 2 or 4-ohm.
Running too little resistance heats up the power source, so you should never run a 2-ohm circuit from an amp that's not 2-ohm stable.
Which sub you get depends on how you're powering it. If your amp is stable at 2 or 4 ohms, you can get either, so you'll have to take other considerations into account (like which box does better on the available power).
Hope that helps.
Dan
Old Jul 11, 2005 | 10:12 AM
nsxxtreme's Avatar
Default Re: 2 or 4 ohms? (LudemanDan)
A speaker has a coil, basically an inductor. The ohms on a speaker represent Resistance + Reactance.
Old Jul 14, 2005 | 06:56 AM
SargentNg's Avatar
Yea, the ohms in speakers is impedance. You have to match up your speakers to your amp. Most amps put out different wattages at different loads. Here's my example:
Two 1000 watt 4 ohm subs wired in parallel for a total impedance of 2 ohms along with an amp that puts out 2000 watts with a 2 ohm load.
If my amp was set up with a 4 ohm load, such as if I wired only one of my subs or if I had two 2 ohm speakers in series, my amp would put out a max of 1200 watts (about half) with the 4 ohm load.
Old Jul 14, 2005 | 07:16 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill3galdr1v3r &raquo;</TD></TR><TR><TD CLASS="quote">ok this may be a newb question to some, but i never understood ohms. i searched for "ohm" and found 1 result which didnt help any. i was just wondering whats the difference between 2 ohms and 4 ohms. im looking into getting alpine type r subs in 10 inch form. but i dont know which one to get. the 2 ohm or 4 ohm. i guess i just need to know what the significance of the ohms are. thanks in advance for clearing this up for me. </TD></TR></TABLE>Go to http://www.the12volt.com lots of very good info for a "newb" charts, diagrams and explanations done so most anyone can understand and be more comfortable installing 12V stuff into your car 94
Old Jul 14, 2005 | 04:55 PM
nsxxtreme's Avatar
When you measure resistance with an ohm meter you only measure the DC component.
Old Jul 19, 2005 | 02:23 PM
silver-gsr's Avatar
mtx got an 8ohm sub
Old Aug 4, 2005 | 12:12 AM
vw eater's Avatar
Default Re: 2 or 4 ohms? (silver-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver-gsr &raquo;</TD></TR><TR><TD CLASS="quote">mtx got an 8ohm sub </TD></TR></TABLE>
i thought the jl w7 was 8 ohm also...?
Old Aug 4, 2005 | 08:33 AM
fcm's Avatar
fcm
Old Fart
Default Re: 2 or 4 ohms? (vw eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw eater &raquo;</TD></TR><TR><TD CLASS="quote">
i thought the jl w7 was 8 ohm also...?</TD></TR></TABLE> They are 3 ohm VC, for the 8", 10", 12" the JL 13W7-D1.5 is a dual 1.5 ohm VC 94
camacho9555
Audio / Security / Video
13
Nov 11, 2010 11:28 AM
CDdubz5
Mar 23, 2010 06:22 PM
mstewar
Sep 10, 2003 06:54 PM
93civdx
Dec 2, 2002 09:13 AM
Jan 31, 2002 10:43 AM
