amp to dvc
Old Nov 9, 2010 | 03:16 PM
camacho9555's Avatar
Default amp to dvc
i have a powerbank 1000.2 amp bridged that is powering 2 10" apline type e's. well i guess a terminal broke on one sub and a voice coil is bad on the other. i want to upgrade and i was looking at the type s. alpine type s has dual voice coil overs rated at either 2 ohms or 4 ohms. i cant find a damn manual for my amp and im not sure how to wire those or if i even can. so which ohm load should i buy 2 or 4 and how would i wire those to my particular amp?
Old Nov 9, 2010 | 03:50 PM
joeymc13's Avatar
Default Re: amp to dvc
I would get the dual 2ohm, wire the subs in series, then bridge at the amp, that would give you a 2 ohm load, but then again, I don't know if that amp is stable at 2 ohms bridged. You need to find that out. If it isn't, then I'd get the dual 4 ohm coils, wire them in series, then bridge at the amp, that way you get a 4 ohm load. Most 2 channel amps are stable with a 4 ohm load while bridged...
Old Nov 9, 2010 | 04:39 PM
edzy's Avatar
More than likely the amp will do it's bridged power @ 4 ohms
Old Nov 10, 2010 | 10:22 AM
mhart's Avatar
looks like the alpine type E subs are single 4 ohm, so you are either running your amp at 2 ohms or 8 ohms, i would think it's 2 ohm. so buy dual 2 ohm if you are running 2 subs
and this link will show you everything you need.
http://mobile.jlaudio.com/support_pages.php?page_id=161
Old Nov 10, 2010 | 12:58 PM
edzy's Avatar
Or, he could be running each off a single channel...
Old Nov 10, 2010 | 01:08 PM
2k.civic.si's Avatar
if you get the dual 4ohm you can get a 4 ohm final load for the amp bridged. with the dual 4ohm you can also do a 1ohm final load on the amp bridged if its 1ohm stable. the dual 2ohm subs i find arent as versatile unless your doing 3 subs or more.
Old Nov 10, 2010 | 01:28 PM
Cobb2819's Avatar
OP - are you gonna be running 2 subs or 1 sub??
Old Nov 10, 2010 | 01:57 PM
2 subs not sure if the amp is stable to 2 definitely not stable at 1 ohm. right now they are bridged and im pushing 2 type e's. planning on 2 type s's. i had them installed by someone so im not sure what the load is now. im still new to the lingo. trying to get a grasp. but its forf sure doable right? im just worried id have to replace my whole set up
Old Nov 10, 2010 | 02:04 PM
after looking at this link its clear how to wire them but whats the difference in ohm impedance? should i aim for lower or higher here? also should i keep the amp bridged?
Old Nov 10, 2010 | 02:07 PM
Cobb2819's Avatar
the amp is bridged?? if it is now, then you can get the dual 2ohm subs, series the voice coil, that nets you 4 on each sub, then run them the same way you are with your type e's
Old Nov 10, 2010 | 02:13 PM
edzy's Avatar
Why not just get 2 single 4's? make it easier to wire up.
Old Nov 11, 2010 | 10:44 AM
mhart's Avatar
the subs he wants are dvc and wiring subs is not hard.
Old Nov 11, 2010 | 10:47 AM
mhart's Avatar
please never do this, a lot of music will be from the left or right( when the song sounds like it's going back and forth) and when subs are hooked up to a left or right channel, they will fight each other, it's best to have them hooked up in a mono way so they work as one sub.
Old Nov 11, 2010 | 11:28 AM
Cobb2819's Avatar
the only way to make both scenerios work is if the source has a mono output. then the amp sees mono sub and not stereo.
94 SIR
Audio / Security / Video
Dec 5, 2008 12:50 PM
cmwright1986
Dec 3, 2006 10:57 PM
bradykiller
Mar 31, 2004 06:48 PM
mstewar
Sep 10, 2003 06:54 PM
Vp Special K
Sep 30, 2002 09:56 PM
