07 Tach Wire
Old Dec 17, 2007 | 01:53 PM
civic_speed99's Avatar
Default 07 Tach Wire
Ok putting my remote start from my old civic to the new one. I need the tach wire for the remote start and I know these coil cars you just can't get anywhere. What do I use. I was going to try an injector but I was told they can cause problems with the car starting 100% of the time. So where should I look, and what color.
Car is an 07 Si 4dr.
Old Dec 17, 2007 | 04:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: 07 Tach Wire (civic_speed99)
I always use an injector lead, it should not cause any starting problems. 94
Old Dec 17, 2007 | 04:58 PM
What side would you use. Yellow or Yellow with black stripe.
Old Dec 17, 2007 | 06:05 PM
B18C_EJ8's Avatar
Whatever one isn't common amongst all 4 injectors...
Old Dec 17, 2007 | 06:28 PM
Ok thanks. I'll give it a look tomorrow. Too damn cold now.
Old Dec 18, 2007 | 10:11 AM
White Smoke's Avatar
i my honda
Global Mod
Pretty sure yellow black will be the ground so use the other one. Double check with a volt/ohm meter.
http://www.the12volt.com/insta...96389
Old Dec 18, 2007 | 03:33 PM
Got it. Thanks
Old Dec 18, 2007 | 03:44 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
NOT blk/wht, black or yel/blk at any ignition coil or fuel injector
hialeahzbg
Audio / Security / Video
23
Aug 31, 2008 12:39 AM
Magic Wheels
Jul 17, 2004 02:03 PM
pnltnc
15
Apr 20, 2004 03:22 AM
preluder
Dec 22, 2002 09:51 PM
Butch
Feb 21, 2002 09:22 AM
