tach hook up
Re: tach hook up (pnltnc)
Thats not the question you want to ask. First you have to know what type of ECU your running then look at the diagram and see where your rpm signal is.
* B A N N E D *
go in to ur engine bay...
right by the windshield whiper wires and the 3 clips by the tower of the driver side there should be a lil black square thing almost look like a plug its gotta rubbery black thing over it... it should be 1 wire that goes in to that black thingy really easy to spot it kut the black thing off and attach the green wire from the tach to that but connect it
Re: tach hook up (JDMHONDACIVICX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHONDACIVICX »</TD></TR><TR><TD CLASS="quote">go in to ur engine bay...
right by the windshield whiper wires and the 3 clips by the tower of the driver side there should be a lil black square thing almost look like a plug its gotta rubbery black thing over it... it should be 1 wire that goes in to that black thingy really easy to spot it kut the black thing off and attach the green wire from the tach to that but connect it </TD></TR></TABLE>
this is the shortest easiest way and i use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnltnc »</TD></TR><TR><TD CLASS="quote">I got an autometer tach. where is the easiest place to run the green wire? Thanx in advance</TD></TR></TABLE>
The easiest place is from the cluster.
