Tippyman's Project Thread
Old Jun 17, 2006 | 07:33 PM
  #151
Tippyman's Avatar
Default Re: (crxpwr1)
Duplicolor is just a brand. They have many different types of paint. If you use their high-temp engine enamel, then yes, it will work. If you used the trim paint like I did, then no, it won't work.
Old Jun 17, 2006 | 07:58 PM
  #152
crxpwr1's Avatar
Default Re: (Tippyman)
ill get a pic tomorrow and you tell me if it will work
Old Jun 17, 2006 | 08:00 PM
  #153
Tippyman's Avatar
K.
Old Jun 18, 2006 | 08:51 AM
  #154
crxpwr1's Avatar
thats the piant I use inside my bay
Old Jun 18, 2006 | 12:28 PM
  #155
UltimX's Avatar
Thats the only one they had, that and some paper stuff.
Old Jun 18, 2006 | 01:37 PM
  #156
hitman187's Avatar
best of luck when all those butt connectors go bad.
engine vibration and moisture will own you!
Old Jun 18, 2006 | 01:42 PM
  #157
Autoworks's Avatar
Default Re: (hitman187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitman187 &raquo;</TD></TR><TR><TD CLASS="quote">best of luck when all those butt connectors go bad.
engine vibration and moisture will own you!</TD></TR></TABLE>
as long as theres some slack in the wire betwwen plugs and its crimped properly, he'll have no problem with a connection vibrating loose. If he decides to leave them, they can be wrapped to kill the concern of moisture.
keep up the work on the build
Old Jun 18, 2006 | 04:41 PM
  #158
Tippyman's Avatar
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
keep up the work on the build </TD></TR></TABLE>
Already did that! You know me man!
Old Jun 19, 2006 | 07:50 PM
  #159
Tippyman's Avatar
<U>***UPDATE 6/19/06***</U>
I went out and got some flange's for the test pipe that I now have to make! The Omni Power seller backed out, so I gotta fab up my own! I had a little trouble finding them, but got them at Napa! Who'da thunk it?
I immediately have a problem though. The donut gasket on the header (or whatever it's called) makes the flange stick out quite a bit!
The Flange:
The Donut Gasket:
And, putting the two together:
I think that all it needs is to be tightened down REAL tight with the exhaust bolts. Wudya think?
Here's a pic of the flange on the header without the donut gasket:
Fit's real flush!
The exhaust pipe flange actually fits awesome, thank God.
What should I do about the header flange?
Old Jun 20, 2006 | 01:45 PM
  #160
Tippyman's Avatar
BUMP. There's still plenty of gasket mat'l visable inside so I'm thinking just bolt it down real hard and it'll take care of it. Think it'll work?
Old Jun 20, 2006 | 02:11 PM
  #161
Got_soy's Avatar
leave the donut and bolt it with the spring bolts
Old Jun 20, 2006 | 02:13 PM
  #162
Tippyman's Avatar
Default Re: (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">leave the donut and bolt it with the spring bolts
It won't leak?
Old Jun 20, 2006 | 06:29 PM
  #163
Got_soy's Avatar
when i put new donut on my exhaust it had a huge gap like that and it didnt leak
Old Jun 20, 2006 | 06:38 PM
  #164
Tippyman's Avatar
Aight, i'll give it a whirl! I hope I got no more shitty buzz!
Old Jun 23, 2006 | 12:24 PM
  #165
hitman187's Avatar
Thats the spirit! Don't be afraid to screw stuff up! There isn't anything you can screw up that someone else can't fix.
My guess is that it should work fine.
Old Jun 25, 2006 | 06:29 PM
  #166
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitman187 &raquo;</TD></TR><TR><TD CLASS="quote">Thats the spirit! Don't be afraid to screw stuff up! There isn't anything you can screw up that someone else can't fix.
That's a helluva attitude!
Old Jun 26, 2006 | 01:09 PM
  #167
Driven's Avatar
i'd put the donut on it. the donut helps with flex and leaks.
Old Jun 26, 2006 | 01:23 PM
  #168
d16efsedan's Avatar
Default Re: (Driven)
Looking good Tippyman!
Old Jun 26, 2006 | 01:51 PM
  #169
Tippyman's Avatar
Default Re: (d16efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch &raquo;</TD></TR><TR><TD CLASS="quote">Looking good Tippyman! </TD></TR></TABLE>
Thanks! I went out and bought some Penzoil Synchromesh MTF for my new Si tranny! Weather allowing, I'll be putting on the tranny/clutch/flywheel along with fabbing up the test pipe and installing the exhaust and header tomorrow and Wednesday. Wish me luck!
I'm hoping that I'll notice a big difference afterwards, mainly due to the tranny.
Old Jun 26, 2006 | 06:16 PM
  #170
Tippyman's Avatar
Well, shitty rain means I will be doing work at MY house tomorrow, not my gf's house with the nice air tools.
I guess I'll just do the header and exhaust tomorrow and since the weather will clear by wed., do the tranny then.
Old Jun 26, 2006 | 06:30 PM
  #171
d16efsedan's Avatar
i wish it would rain here in texas so i could get started on my wire tuck:-p.keep up updated tippyman!
Old Jun 26, 2006 | 06:32 PM
  #172
JJ's civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Well, shitty rain means I will be doing work at MY house tomorrow, not my gf's house with the nice air tools.
I guess I'll just do the header and exhaust tomorrow and since the weather will clear by wed., do the tranny then.</TD></TR></TABLE>
i'm sick of this damn rain i need to pull my motor out of my parts/furture project. so i can get it ready to go into my dd but this rain is killing me. i need a garage.
Old Jun 26, 2006 | 06:37 PM
  #173
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch &raquo;</TD></TR><TR><TD CLASS="quote">keep us updated tippyman! </TD></TR></TABLE>
Will do!
BTW: Do you guys think I'll notice much of a diff. with the new exhaust and header? I'm trying to anticipate what It'll feel like and I can't imagine it being all that panty-wetting.
Old Jun 26, 2006 | 06:39 PM
  #174
d16efsedan's Avatar
i dont see you feeling much of a improvment but you'll hear it for sure page 8 ownage
Old Jun 26, 2006 | 08:38 PM
  #175
Tippyman's Avatar
I'll post pix after I start doing **** tomorrow!
