a simplified awd build
Old Nov 22, 2012 | 02:55 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default a simplified awd build
seeing so many sucessful awd builds I just couldn't help but wanna do my own. this will all be going on my eg hatch that has a built 84mm lsv on e85 that made 408whp on 16lbs. if everything works out Ill probably raise the boost a bit more and shoot for 500awhp more pics this weekend.
after I picked up all the drivetrain parts from both the crv and wagovan I started doing a bit more research. I found that the wagon rear diffs prove to be very stout also the wagon rear axles are much larger diameter. I decided to go with the crv trans, drive shaft front and rear hubs and wagon rear diff and axles.
parts list used on the build:
crv front hubs (same as jdm itr)
97-01 base model prelude axles, yes the plug right in and work with 36mm hubs.
crv 5 speed tranny (works with any b series hydro clutch thats right awd with a twin disc!
crv drive shaft (may switch to a wagon one down the road if the crv driveshaft doesn't hold up)
wagovan rt4wd rear end
two drivers side wagon rear axles (dr side is 1.75" longer then the passenger side axle)
crv rear hubs, unbolted from crv trailing arms and welded to bored out eg trailing arms
all new ss brake lines
all new sloted and drilled rotors
energy suspension rear trailing arm bushings
all new front tie rod ends
new front camber kit
my goal for this car is to have a powerful civic that will have usable power on the street and strip. Id like the car to run low 11's on street tires and still handle well.
Old Nov 22, 2012 | 11:02 PM
88ED8's Avatar
Default Re: another 4wd civic build
Nice, I'll be keeping an eye on this!
I have the AWD Wago rear sub frame for sale if you need it..
Old Nov 23, 2012 | 10:34 PM
Loved
Community Favorite
for sure but It wouldn't really be cost effective since your in florida and Im in oregon lol. picking up a ton of stuff tomorrow. heres a pic of the car currently.
Old Nov 24, 2012 | 01:01 PM
HOMEMADEPOWER's Avatar
Nice hatch. Can't wait to see how your build turns out.
Old Nov 24, 2012 | 03:55 PM
716pro's Avatar
I have all those parts if you need them, I am parting a CRV, everything must go.
Old Nov 24, 2012 | 11:08 PM
Loved
Community Favorite
got a ton of stuff today but there is a few things missing Ill need, I need the shifter cable brackets off the crv tranny, if I can't find one on here Ill try honda. getting wagon rear diff, axles and trailing arms tomorrow so the crv diff and axles will be for sale if any one is interested.
Old Nov 25, 2012 | 01:07 AM
88ED8's Avatar
May I ask why you are going with the wago rear end vs. the CRV rear?
Old Nov 25, 2012 | 04:24 PM
Loved
Community Favorite
as far as Iv found its alot more stout. also the wagon axles are much thicker and shorter so I won't have to shorten them down to fit it in my eg. Ill be selling the crv diff as well as wagon rear trailing arms and a wagon rear sub frame if any ones interested.
here is some of the stuff I picked up.
Old Nov 25, 2012 | 09:57 PM
88ED8's Avatar
Can you take more/ better pics of the CRV rear sub frame and measure the width of the mounting holes up top for me, thanks!
Also, is it for sale, if it is.. Save it for me!
Old Nov 25, 2012 | 11:12 PM
Loved
Community Favorite
for sure message me and I can take some tomorrow for you. I just posted it up for $75 plus shipping if you want it .
got some work done. picked up a pair of eg drum brake rear trailing arms, I need to replace both rear trailing arm bushings but other then that they are in good shape and no better price then free right
pulled the drums off and marked where I needed to widen the opening for the axles to fit.
cut out.
crv hub hanging out till I build a jig and weld it in. looks like the crv hubs make the rear wheels sit in about 10-15mm more then the other one. either the break rotor will fill up that gap or some wheel spacers. doing arp extended lugs all around.
Old Dec 1, 2012 | 09:46 AM
Loved
Community Favorite
been a busy week at the shop so I haven't had time to work on my project much but I have made a little progress here and there. got the old trailing arm bushings burnt out and new ones pressed in. had to use some ghetto engineering to make it work but they went in without a problem lol. got all my arp extended wheel studs in the mail and having my buddy use his press to install them. still need some prelude 5 lug rear disc and calipers to use and a few other nic nak things but its coming along. bought a 5 speed cable shifter bracket for my tranny new from honda for $48 shipped.
Old Dec 3, 2012 | 08:07 PM
Loved
Community Favorite
more pics.
Old Dec 5, 2012 | 12:05 AM
the171's Avatar
cool build
Old Dec 6, 2012 | 12:44 PM
Loved
Community Favorite
figuring out my fuel cell setup today. not sure If I wanna stick to dual wallys and put my in tank inside the fuel cell or if I wanna use the fittings that it has sumped already. going to go down to a local performance shop with a old time drag racer owner and talk to him to get a few ideas.
Old Dec 6, 2012 | 12:52 PM
JuggerNaut-CTR's Avatar
How much of a pita was it to get those bushings in?
Sub'd
Old Dec 6, 2012 | 01:02 PM
Loved
Community Favorite
they really weren't bad at all really. I lubed the **** out of them and they pretty much went right in. burning the old ones out was way more time consuming then I would have thought though.
Old Dec 7, 2012 | 02:48 PM
Loved
Community Favorite
the one part on this build that has been stressing me out has been the fuel cell setup since Iv never dealt with this sort of stuff. fortunately everything ended up being very easy and I was able to modify a cheap fuel cell that I got hooked up from a buddy on to fit my dual walbro setup. the cell was a sumped cell and I figured out how to make the dual wallys sit right in the deepest part of it which is perfect.
does any one know the nhra rules on fuel cells? if so Id love to hear what I would need to do to make sure this ends up being track legal.
half finished backing plate to hold the pumps in nice and sturdy.
Old Dec 9, 2012 | 05:15 AM
Loved
Community Favorite
pulled and sold my old tranny yesterday along with the axles, shift linkage, t bracket and my old wheels. did a side by side comparison so you can see the difference in how the rear T bracket sits. Im going to be working on the rear T bracket today as well as the passenger side tranny mount.
why take apart a perfectly good 400whp car? hopefully this is worth it in the end
tilton twin disc.
old gsr lsd tranny.
crv trans.
gsr trans.
test fitment #1.
Old Dec 10, 2012 | 12:40 PM
ale5six1's Avatar
subscribed! this is going to be exciting to see! thanks for the pics!
Old Dec 10, 2012 | 10:53 PM
Loved
Community Favorite
no problem. hopefully Ill get a few more people interested in this as well through this thread.
made some more progress this weekend, fabbed a jig and a tranny mount as well as modded the rear T bracket. also got the rear hubs and front hubs bolted up with ss lines all around, new rotors and pads. still have to fab the rear caliper mounts as well as rear diff mount but its coming along.
new shifter bracket.
Old Dec 11, 2012 | 07:11 AM
ale5six1's Avatar
I saw on another thread that you were on, someone said your located in Florida? this true? b/c I'm in west palm beach
Old Dec 11, 2012 | 07:32 AM
^No he is in washington or oregon...forget which
Old Dec 11, 2012 | 07:34 AM
ale5six1's Avatar
his Facebook says oregon :/ damn...
Old Dec 11, 2012 | 09:26 PM
Loved
Community Favorite
yup. good Ol' orygun. got a bunch done today, Ill post some pics when I can.
Old Dec 11, 2012 | 10:55 PM
Justinhondapoor's Avatar
to bad i wont get to see this any time soon guess have to see the videos
