Red EG8 Project
Old Feb 14, 2013 | 06:34 PM
  #76
ROMOJDM's Avatar
Default Re: Red EG8 Project
Old Feb 15, 2013 | 02:17 PM
  #77
EscoSi's Avatar
love how the car's looking... esp the engine bay! i have a friend of mine here in ja with a 94 si but he has on the hatchback front bumper. looks pretty awesome on the car. keep up the work though. can't wait to see how the splitter comes out. maybe you wrap it with 3M cf vinyl... just a thought
Old Feb 15, 2013 | 11:43 PM
  #78
USDM as fuhh's Avatar
Originally Posted by j.red
"so I polished my **** out of boredom"
We've all been there. Love the build man, coming along quite nicely. I love seeing sedans pulled off properly
Old Feb 16, 2013 | 11:57 AM
  #79
j.red's Avatar
thank you all.
these just showed up today.
also balanced the tires this afternoon and road force tested them. ranged from 3-6 lbs. of road force.
Old Feb 16, 2013 | 01:21 PM
  #80
brsteinbach's Avatar
Awesome man! I just went through and read all of your build. Nice job.
Old Feb 16, 2013 | 04:44 PM
  #81
j.red's Avatar
Lost 3 good sockets to these damn things.
Old Feb 16, 2013 | 09:21 PM
  #82
Boosted_90Teg's Avatar
To the rear camber bolts? o_O Yikes, and I thought mine were stuck on there, though nothing some PB Blaster and some heat from a torch wouldn't fix, lol.
Good luck though, my buddy had the Hardrace parts on his EF front and back a while ago, great pieces.
Old Feb 17, 2013 | 05:20 AM
  #83
j.red's Avatar
2 of the 3 were broken after heating it with a torch.
I finally got the threads loose, but the bushings were totally seized on the bolts and the ears on the trailing arm were just pushing apart rather than the bolt coming through the bushing. Used a sawzall on the bolt on each is of the bushing and had to grab on to what was left of the threaded side with vicegrips to screw it out all the way.
Old Feb 17, 2013 | 05:41 PM
  #84
j.red's Avatar
All four wheels are finally on.
Now I can play with my coilovers a little bit.
Old Feb 17, 2013 | 06:06 PM
  #85
Khnemu's Avatar
Sick build! I'm going through an engine build like you did. Eventually going into my EM1. :O
The diffuser looks great!
Old Feb 18, 2013 | 07:04 PM
  #86
pinoy_boi's Avatar
Dayum Those were snap on too!! What were you using? 6 foot breaker bar? lol jk man. Nice investment on the camber arms. Heard nothing but good things about hard race. I want their toe arms cause adjusting toe on my car is a pain, especially since I want to zero it out lol
Old Feb 19, 2013 | 04:47 PM
  #87
j.red's Avatar
Yeah. The sockets broke after i used a torch to heat the bolt...but they were also over 20 years old. Both the rusty bolts and the sockets.
I'm probably going to end up getting the hardrace toe adjustments too so that I can add a little toe in to combat the negative camber wear. But I'm waiting until I can get it in on the alignment rack to check where it's at.
Old Feb 19, 2013 | 05:11 PM
  #88
jkid559_EG8's Avatar
this eg8 is a beauty all around
Old Feb 19, 2013 | 06:27 PM
  #89
j.red's Avatar
thanks. few more pictures.
Attachment 533266
Attachment 533267
Attachment 533268
Old Feb 20, 2013 | 05:50 PM
  #90
j.red's Avatar
New valve cover
Attachment 533260
Attachment 532782
Old Feb 21, 2013 | 02:09 PM
  #91
j.red's Avatar
New JDM ITR Leather shift boot. And more importantly, the shift boot bracket which I never had because auto-manual conversion.
Old Feb 22, 2013 | 05:16 AM
  #92
Looking good bud!
Old Feb 23, 2013 | 07:26 AM
  #93
gabebauman's Avatar
Subscribed. Very Nice!
Old Feb 23, 2013 | 11:51 AM
  #94
j.red's Avatar
Thanks people! Just ordered hasport u70a motor mounts, asr rear subframe brace, asr 24mm sway bar, asr spherical end links, and bwr lca's. Also on the way is a couple mugen pieces.
I need to stop spending money for a while, so I'm going to try to cut back on this the next couple weeks. But I still plan on getting a 70mm throttle body before driving weather hits. Possibly an intake manifold too, but we'll see.
Old Feb 23, 2013 | 12:16 PM
  #95
DiRty Dc4's Avatar
did you plug up the pvc whole on the valve cover?
Old Feb 23, 2013 | 12:23 PM
  #96
JohnbakerEg's Avatar
That is very clean bro I like it a lot
Old Feb 23, 2013 | 01:01 PM
  #97
j.red's Avatar
yes. It's an obd1 motor. the original valve cover didn't have that, the pcv valve is under my intake.
Old Feb 23, 2013 | 01:03 PM
  #98
Aarron_M's Avatar
Really great build! Just read all 4 pages. I honestly liked the older vc better, but it's your car, like you said earlier.
I'd like to know what you're doing about the rear tires and the fenders? Definitely looks like they'll rub unless you're at stock height.
Old Feb 23, 2013 | 01:51 PM
  #99
j.red's Avatar
That's what I got the rear camber kit for. As they are right now, they look like they're going to just clear. But I'm also going to probably trim off a little bit of the lip inside the fender in the spots that it's a little thicker and closer to the tire.
Old Feb 23, 2013 | 02:24 PM
  #100
gabebauman's Avatar
15x7 +36 wheels and 205/50R15 direzza zII's
Have you tried rolling the fenders at all? I run 15x7 +38 Kosei K1's with a 205/50/15 Toyo R888 tire in the rear and I have no rubbing issues at all. I rolled the fenders so that the lip is tucked up tight. My rear camber is fairly mild too...only about -1.2/-1.3 max.
