Panchoek's build thread
Old Jun 14, 2016 | 03:48 PM
  #151
PanchoEK's Avatar
Default Re: Panchoek's build thread
Originally Posted by WeBuildStance
Man, this car really did pass a lot of stages, how nice is that? Keep going!
Can you share with us the specs of those RPF-1's?
Silver ones are 15x8 +28, black ones are 15x7 +35
Old Jun 14, 2016 | 09:46 PM
  #152
B16B Four Door's Avatar
I just got done reading through your whole build and I love the progress you've made! Man that b20 was ripping before the rings went out on you! I'm sure the b20V will be killer when it's done
Old Jun 15, 2016 | 02:48 PM
  #153
bonspeed's Avatar
sorry to hear about the piston rings man, but I can't wait to see it finished with the new vtec head and other goodies
Old Jun 21, 2016 | 01:35 PM
  #154
PanchoEK's Avatar
yea I'm excited also, probably not going to happen until next year!
vtec valve cover came, first up is stripping it and primer!
yea, that will look great in the bay
first time using paint stripper
almost there
all stripped
taped up and primered at work
after I get some -10 AN bungs welded in for the catch can I will be using VHT wrinkle red to finish it off!!
Old Jun 26, 2016 | 07:29 AM
  #155
PanchoEK's Avatar
go-kart track day again!! was able to accomplish my personal goal for this year, after being in the 1:18's for about a year and half, yesterday I was 1:17's all day. I was able to put down a 1:17.09 twice!! unfortunately the track will be getting demolished next year so the new goal for the next 2 events there is to get in the 1:16's.
Old Jun 26, 2016 | 07:39 AM
  #156
Josip.'s Avatar
5 Year Member
Is it faster than his buddy's EVO & STI?
Old Jun 27, 2016 | 01:07 PM
  #157
PanchoEK's Avatar
About 4 seconds faster than the white subie and 1 second behind the white evo. I've got track record for fastest FWD with my 1:17.09. Track record for street car is the red evo from before woth 1:15.90, the white evo got a 1:15.95
Old Jun 28, 2016 | 01:41 AM
  #158
Josip.'s Avatar
5 Year Member
I bet you're proud as f*ck. :D
Old Jul 12, 2016 | 03:04 PM
  #159
PanchoEK's Avatar
double header this past weekend, finished mid pack. needed a bit more power
on sunday we got a wave of rain. pictures are about an hour apart
and videos
Old Jul 14, 2016 | 09:31 PM
  #160
WeBuildStance's Avatar
Looking great so far! What a difference of weather in one hour, damn
Old Jul 15, 2016 | 11:07 AM
  #161
Josip.'s Avatar
5 Year Member
Do you see any differences with that splitter?
Old Jul 29, 2016 | 02:41 PM
  #162
PanchoEK's Avatar
Update: i was debating for a while whether to sell my subie or keep it for another 2 years to pay it off. went to Carmax to see what they offered and left with 19k, after 14.5 payoff, came out with 4.5K. ive been trying to find another cheap daily but i think I'm just going to finish my b20v this year. so heres a big parts update.. after debating and some persuasion from a couple guys I've decided to run the b20v on E85!! so I ended ordering bigger injectors, fuel pump, and extra jug for when I go out of town racing! For ecu ill be going with obd1 Hondata S300 which is the only thing I have left to order. the last thing I'm looking for now is an EM1 wiring harness so I don't have to cut or splice any wires.
one last pic of the subie
and parts pic
oem parts:
oil pump, tensioner, PS bracket, VC gaskets, misc.
NGK wires
NGK spark plugs
Walbro 255 fuel pump
ID 1000's
ACL Thrust, rod, and main bearings
Password JDM oil baffle, magnetic drain bolts
VP racing 5gl jug
Skunk 2 VC grommet kit
found some downtime in a couple weeks, hopefully the new build will begin then
Old Aug 8, 2016 | 02:06 PM
  #163
PanchoEK's Avatar
Finally after 2 1/2 weeks got my RS machine pistons.. ECU is ordered and waiting on arrival. only thing left is the wiring harness!
Got the valve cover sprayed also, wrinkle is really inconsistent even when I went through all the directions correctly. also got a spark plug wire cover
Motor is coming out next week for rebuild, really excited. if all goes well, I will still be able to get 8 or 9 events on the new setup
Old Aug 9, 2016 | 03:33 AM
  #164
NotoriousEK's Avatar
Looks good dude glad the plug cover arrived finally.
Old Aug 9, 2016 | 12:20 PM
  #165
If you were setting records with the stock b20 in curious to see what your do with the new setup. It should be a lot of fun and I'm sure you'll give your friend in the evo a run for his money
Old Aug 10, 2016 | 09:12 AM
  #166
Josip.'s Avatar
5 Year Member
Cover looks great, just like original.
Btw, can someone pls tell me what for are those two holes? I see that a lot, but don't know what for is it.
Old Aug 10, 2016 | 01:01 PM
  #167
PanchoEK's Avatar
thanks, looks great on the valve cover
already do on a cone course, can't wait to see what it does now!
thanks, and holes are AN male bungs for oil catch can
Old Aug 14, 2016 | 03:35 PM
  #168
PanchoEK's Avatar
cars was acting up lately, took the distributor cap off and I think I found the problem
was going to take out the motor this weekend anyways but since I couldn't get a distributor just pulled it out Friday/Saturday, relatively easy except I ran into a bit of trouble with the bitch pin, so I looks like it will be permanently stuck on the linkage.. not worried right now until I have to actually need to take it out.. also ordered a few more parts and Hondata ecu came in also
getting ready start the tear down!!
Friday evening, all I had left were the motor mounts
Saturday morning
next up is drop it off for disassembly and machine shop! about 3 weeks hoping to have it back in and tuned!
Old Sep 4, 2016 | 03:39 PM
  #169
PanchoEK's Avatar
time for update!! didn't take many inbetween pictures since I get into the zone once i start putting the motor back in! the casting was so shitty from the intake manifold, i had them port match and it looks great!
fluid stock up
after getting the motor back and dropping it in, still had the suspension, axles, and header to install
finally on the ground and out of the garage!!
hood back/bumper back on, catch can and lines ran!!
first fuel up, dyno tune is coming up next, we'll see how much she makes!!
Old Sep 11, 2016 | 02:40 PM
  #170
PanchoEK's Avatar
finally got the car dyno tuned and it made 195hp/150tq. kinda disappointed but I think its in the cams.. probably going to switch to pro2's in winter
first event today on new setup, car felt great and definitely felt the power difference. it was a pretty tight course so can't wait to open it up on a different course
Old Nov 2, 2016 | 02:49 PM
  #171
PanchoEK's Avatar
with the off season starting, time for an update and future goals
starting off with some unfortunate happening, after coming off my second run I come to my grid spot and hit the brakes and they go all the way to the floor. I was pumping it hoping it would come back but it wasn't and it looked like a puddle of fluid. I jack up the car and find this!
500 mile oil change on rebuilt motor before brake lines busted
waiting for my ride, good time for pics
with my luck, it happened to be an event that was 3 hours away with no one familiar so had to call some back up for a ride back home
lines were a bitch to get on, ended up doing both lines to the rear, and fuel return and fuel feed lines. had to drop the tank and front subframe a bit.
the modding didn't stop there though, got it buttoned up and also had a bucket seat installed. PCI rails and momo evo Daytona seat!
sigh of relieve pic after getting the lines put it and finally on the ground again
video of the 2nd run before lines busted, ended up finishing 11th raw with only 2 runs
I was still able to get a few events after the fixing it.
Iowa Speedway event, with buddy that finished with FTD
second to last event car was understeering like crazy, tires were shot!
Old Nov 2, 2016 | 03:06 PM
  #172
PanchoEK's Avatar
last event of the season
also was wanting to try a more aggressive wing.. decided with a BYC wing, I had it mocked up was waiting on some mounts. should be on there solid this week
2017 plans, not much but something to keep me working
ASR Rear Sway Bar
Skunk 2 Pro2 Cams
EX front brake upgrade:
DBA T3 4000 rotors
Rockauto calipers
Carbotech AX6 pads
Old Nov 5, 2016 | 09:25 AM
  #173
DVDr's Avatar
love this build ! .
Old Nov 20, 2016 | 03:59 PM
  #174
PanchoEK's Avatar
Originally Posted by DVDr
love this build ! .
thank you
got the bearings pressed in along with ARP studs got the new brakes in, looks like a larger MC is in sight of the near future
larger surface area on the brake pad
side by side
assembled on vehicle
random gas station pic
Old Mar 18, 2017 | 08:33 AM
  #175
PanchoEK's Avatar
still alive, will bring an update here shortly, a little livery on the car and exhaust ****
