my project
Old May 15, 2006 | 05:54 PM
  #176
ludesrv's Avatar
I'm sad now cause my is rusty...
Old May 16, 2006 | 12:45 PM
  #177
eda6's Avatar
Default Draft:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeaclearerskyxx &raquo;</TD></TR><TR><TD CLASS="quote">wow! you make me want to do this...if only i had another car to drive... </TD></TR></TABLE>
sounds like it's time for you to get another ED/EE/EF and make it happen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lookinaround &raquo;</TD></TR><TR><TD CLASS="quote">Man i really loved your home made paint booth set up. Seems to have worked great!</TD></TR></TABLE>
although it fell down twice the booth worked well. if anyone plans to duplicate it put tape on the top of the plastic, cut slits in the tape, run your ziptie through the slits and screw it to the wall. use of a ziptie that screws to the wall is imperative or it will fall down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">hey looks good eda6..by the way did you use base/clear or what???
let me know and ill fill you in on some more tips about buffing that way your car will shine!!!</TD></TR></TABLE>
used omni au urethane paint w/o clear
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squallie &raquo;</TD></TR><TR><TD CLASS="quote">wow, first post in months....and i come back to a thread like this . i myself have plans on doing something somewhat similar. looking to do mine in a NHBP or even a Cranberry color that came on the Lexus's. very good thread though. any other plans for it?</TD></TR></TABLE>
thank you. after the paint is done and the car is reconstucted i'm going to attend efi 101. After that i'm going to do a build (most likely an all motor poormans R) and tune it myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991civicsi &raquo;</TD></TR><TR><TD CLASS="quote">Great job! That looks better than some local body shops by me. We all really appreciate you taking the time to document your progress by taking all those photos.</TD></TR></TABLE>
thanks. i checked out local body and paint shops and wasn't impressed, not even a little bit. Plus i'm paranoid about leaving my car at a shop anyways so this had to be a diy project. The car didn't turn out perfect, but it looks 10x better than a job from a production shop. i saved hella money and learned alot and i'm sure people who read this also learned something.
i'm glad everyone is enjoying the pics so here's more....
the flaws....i don't know how the happened.... must have been the fumes.
Looks bad now but it will look good when i'm done with it.
Look at the middle of the door below and to the right of the handle. i thought there was something on my screen until i started sanding Lol. i'm working on making that spot disappear.
fender is almost done. Notice how the color changes from front to rear.
fender up close
update-started wetsanding with 1500 and 2000 wet yesterday. seems like each panel is going to require a 1/2 sheet of paper so i need to stock up. still looking for a buffer and buffing compounds.
Modified by eda6 at 5:07 PM 5/16/2006
Old May 16, 2006 | 01:46 PM
  #178
Tippyman's Avatar
Old May 16, 2006 | 02:25 PM
  #179
godruler's Avatar
Default Re: (Tippyman)
awsome diy paint job man, mad probs for that ****. one tip i'll give ya on your wetsanding though is don't sand it until your ready to buff it, once you cut into the paint your opening up more pores in the paint and allowing it to cure faster so you'll notice it'll probably take you 2-3x the time to buff a panel that was sanded even as little as a 1/2 day prior than it would if your were to just sand and buff right away. when you buff make sure you get 2 different pads, i usually use a wool pad with a medium grit mechanical cut compound for actually melting out the scratches than i use a foam polishing pad and a nice 3M finishing polish for getting rid of swirl marks and bringin it up to shine. good luck
Old May 20, 2006 | 07:26 AM
  #180
eda6's Avatar
^^^thank you and thanks for the info.
update-I spent about 12 hrs over a 3 day period wetsanding with 1500.
roof was wetsanded. The gas lid still needs to be done.
haven't found the right buffer yet so i hand buffed it for now.
primered the floor last night.
Old May 20, 2006 | 07:37 AM
  #181
stockbee's Avatar
looking better and better.
Old May 20, 2006 | 07:53 AM
  #182
r1ch1e's Avatar
Default Re: (stockbee)
wow excellent job. i'm speechless the car is beautifyl.......
Old May 20, 2006 | 08:07 AM
  #183
ef8 mcm's Avatar
Default Re: (r1ch1e)
that ***** starting to look real good. i like the color!
Old May 20, 2006 | 11:34 AM
  #184
Tippyman's Avatar
How u gonna fix the hatch part?
Old May 20, 2006 | 01:21 PM
  #185
arthurcruz1's Avatar
Damn great project man, read all of the pages, definately subscribing to this!
Keep us posted!
Old May 20, 2006 | 01:33 PM
  #186
SiR Inspired ED7's Avatar
Default Re: (eda6)
Damn, Very Nice, I'm Impressed. Good JOB! Makes me want my paint job faster and faster!
Old May 20, 2006 | 08:32 PM
  #187
1989CivicSi's Avatar
Default Re: (88 Crx Si)
Looks great!
What kinds of buffers are you looking at? I just ordered a Porter Cable myself last night, but I'm assuming you're looking more into the "professional" department?
Old May 20, 2006 | 08:41 PM
  #188
Honda Andy's Avatar
Default Re: (allmotoralldayeveryday)
Whatever time and expense you put into it, you will realize a safe investment. I've seen my '91 Hatchback go from $1200 to $3200 valuation (avg listing in media) since the gas prices started rising. In the meantime, you have probably the best handling compact on the planet. At least, in the 4-5 passenger category. And the styling is still ahead of the competition. Good luck and have fun!
Old May 22, 2006 | 07:20 PM
  #189
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">How u gonna fix the hatch part?</TD></TR></TABLE>
When i removed the tape from under the rear window i didn't like the transition and there's that spot where the hose touched the hatch. I have a bad habit of sanding too much so i ended up burning through an edge on the fender. There's a few more edges that i didn't burn through, but took away too much paint. All the flaws justifiy a respray.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Looks great!
What kinds of buffers are you looking at? </TD></TR></TABLE>
thank you. I'm considering this one. The specs look good plus i can pick it up and save on shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered a Porter Cable myself last night, but I'm assuming you're looking more into the "professional" department?</TD></TR></TABLE>
nope, i'm looking for the one that's the most bang for the buck.
update-I've been reading up on repainting and orangepeel and i got my hands on a PPG Fleet Refinish Training Handbook. I'm not going to follow the manufacturers instructions when mixing the paint this time. I'm going to play with the blend to get a lower viscosity and increase dry time hoping to reduce orangepeel and minimalize wetsanding afterwards.
after i'm done wetsanding the booth will be reconstructed.
Old May 23, 2006 | 11:01 AM
  #190
JJ's civic's Avatar
Default Re: (eda6)
good luck hope everything work out
Old May 23, 2006 | 11:34 AM
  #191
JapJunkie's Avatar
Default Re: (joeny12985)
Old May 23, 2006 | 02:31 PM
  #192
B_CRUZ!'s Avatar
great thread!
Old May 24, 2006 | 12:10 AM
  #193
Default Re: (B_Cruz)
Sorry to hear about the paint defects, but for your first try that actually looked pretty good! Keep it up and your second try will be awesome for sure .
Old May 24, 2006 | 02:38 AM
  #194
Biturbo's Avatar
Nice work! i whont to try....
Old May 27, 2006 | 11:38 AM
  #195
turn2quick4u's Avatar
From: From the East side, and loving the West side, UnitedStates
awsome job man looks dope
Old May 27, 2006 | 11:48 AM
  #196
SD_Lurker's Avatar
HT White Ops
Default Re: (turn2quick4u)
Old May 27, 2006 | 03:08 PM
  #197
melloman's Avatar
Default Re: (nicks_jdmstyle_ef9)
Good luck man And I hope everything works out for the best
-melloman
Old May 29, 2006 | 02:43 PM
  #198
eda6's Avatar
update-exterior is ready for more paint. used electrical tape to protect the edges while I wetsanded the car with 800. I've been going back and forth on painting the interior and door jams and decided i'm going to paint them.
remembered i had this spray bottle in the van, so at 1am this morning i filled it up and started wetsanding the interior. 2 heinekens, 3 hours and 4 refills later the interior was finally done.
As usual i got carried away. next thing i know the doors and cable ties were removed. the clips holding the brake lines were removed and a couple clips were temporarily relocated. I was careful removing the clips and cable ties so that they could be reused. Once i removed the ebrake the car started rolling forward. That header is my temporary ebrake.
I appreciate the postive comments. thanks guys.
Old May 29, 2006 | 03:02 PM
  #199
Autoworks's Avatar
Default Re: (eda6)
flat out excellent build and DIY bodywork that looks better than alot of proffesional shop work
Old May 29, 2006 | 03:09 PM
  #200
89efhatchcrap's Avatar
Default Re: (eda6)
haha notice the HONDA lawnmower in the background...
Nice job man...im loving the new paint...wish i had the time a patience to do all that to my ride
