Timing issue!!
Old 04-29-2005, 07:16 AM
AllMotorDA9's Avatar
Default Timing issue!!
I just replaced the timing belt and tensioner and aligned the crank pulley at TDC then lined the cams to the holes. But here is where im confused. The head is milled .030 and i have no idea where the STR cam gears should be set at. Also anybody have any suggestions on tightening the timing belt. It seems whatever i do i still have slack on one side.
My set-up is:
b20b
stock bottom end
P&P LS head (milled .030)
95 ls cams
skunk2 i/m
jdm DC 4-1 header
RC 270 injectors (does no good)
STR fuel rail
STR cam gears
apexi S-AFC
B&M fuel reg.
I think ill keep the cam gears set at 0 then set the crank, align the cams to the holes then try my best to tighten the timing belt then from there ill screw with the cam gears.
Please anybody that has done this before and knows the steps please help me out. I need to get this thing running right.
thanks, aaron
Old 04-29-2005, 08:24 AM
Default Re: Timing issue!! (AllMotorDA9)
bump this mother
Old 04-29-2005, 09:31 AM
bum..
Old 04-29-2005, 12:01 PM
can i get one reply atleast.
Old 04-29-2005, 12:51 PM
IHateJDM's Avatar
If you have adjustable cam gears, just put them at tdc, and take the rest out with a timing light adjusting the gears. As far as the tension, it needs to be tight on the exhaust side, the intake side can have some slack. Make sure you crank the motor over 2-3 times by hand so the tensioner has time to do it's thing. Hope that helps. If not, at least it was a reply.
Old 04-29-2005, 01:14 PM
Default Re: Timing issue!! (IHateJDM)
Thanks for the reply, so ill make sure its snug on the exhaust side. This is one difficult sumofabitch to get correctly timed.
Old 04-29-2005, 01:17 PM
IHateJDM's Avatar
I bet it is. Just think, the crank turns the motor counterclockwise and the belt pulls the cam gears, so there really isn't any stress on the intake side. Between your dizzy and cam gears, I'm sure you'll be able to get the timing right.
Old 04-29-2005, 02:00 PM
I appreciate the advice, thanks
Old 04-29-2005, 03:08 PM
Old 05-02-2005, 03:56 PM
VtecSpool's Avatar
jello
Old 05-03-2005, 09:03 AM
Default Re: Timing issue!! (VtecSpool)
Everything is alright now (for those who care). Set the crank and cam to TDC then warmed it up and put the timing light on it and seems to run like a champ. But im debating where to set my cam gears at to equal 0,0 becuase of the head being milled. My top end has taking a crap on me .
Old 05-03-2005, 09:31 AM
IHateJDM's Avatar
advance your dizzy a little and you'll lose some low end and pick up top end. It's not much of a change, but it helps.
Old 05-04-2005, 04:19 AM
I think my timing is still off, becuase i have to retard my dizzy fully in order for the lines to come even close.
_Bug_
15
10-13-2006 01:10 AM
cooteg6
05-09-2006 03:12 PM
ITRfaithful
10-28-2003 09:58 PM
Quick Reply: Timing issue!!
