max reving with p72 rods
Old 08-14-2007, 04:23 PM
jcvelez360's Avatar
Default max reving with p72 rods
i got a simple question; i got p 72 rods with stok bolts on it, what is the max reving that it can handle for long term reliability. my problen is the botom end, i got all the upgrades on the head, and im about to tune it so i need to now haw high can i go.
i also got a Knifedge / Micro polished p72 crank and itr pistons.
i had serch for a long time the thiferensses betwen p73 and p72 rods but i havent succed on find some thing clear.
Old 08-14-2007, 04:48 PM
jcvelez360's Avatar
please; its very important for me.
Old 08-14-2007, 05:27 PM
DC2 Mang's Avatar
Default Re: max reving with p72 rods (jcvelez360)
gsr and itr rods are no different than eachother
I dont see any reason the stock rods and rod bolts wouldnt be safe to 9,000 rpms and possibly higher
Old 08-14-2007, 05:38 PM
1_bad_EF's Avatar
Default Re: max reving with p72 rods (DC2 Mang)
https://honda-tech.com/zerothread?id=1202102
Old 08-14-2007, 07:33 PM
jcvelez360's Avatar
ok and if i use arp bolts on it, it would be better ?? it realy wort it??
it would take mor rpm with those rod bolts??
and wish kind of arp bolts are the ones for mi?
Old 08-14-2007, 08:05 PM
DC2 Mang's Avatar
Default Re: (jcvelez360)
have you gotten the car dyno'd yet?
if so look at your peak power, you should only be revving a few hundred rpms past that, otherwise it it useless to spin the motor higher
Old 08-14-2007, 08:13 PM
Chris Tune's Avatar
you can rev to the moon...
Old 08-16-2007, 02:23 AM
jcvelez360's Avatar
Default Re: (Chris Tune)
i havent, b wath i wanth i s ture it can handle as many rpm as i need, that the reason im asking for a numbe
Old 08-16-2007, 08:07 AM
drift4jesus's Avatar
I wouldn't go any higher than 84-8600 if you are still even making power up there. GSR and ITR rods are very similar. itr rods have a nifty little R on the side of them instead of a p72. They share the same caps though. They also come with dimples in the end of the bolts so that bolt stretch can be checked from the factory.
9mm arp bolts are the ones you would need for these. In my experience they were good to about 9200 rpm before they stretched enough to have the domes on the pistons close the gap on the spark plugs and shut the motor down.
Old 08-16-2007, 02:03 PM
b17a1db2's Avatar
Default Re: (drift4jesus)
i've taken mine to 9K rpms many times, nothing bad happens. and the bottom end is stock..
Old 08-16-2007, 02:34 PM
jcvelez360's Avatar
ok that helps me a lot.
is better to use the arp bolts than the stock ones??
Old 08-16-2007, 02:50 PM
jcvelez360's Avatar
if y get it to 9200 all the time a would have reliability???.
abo the diferensses betwen p72 and p73 rods, are it real mede of dierent material??
Old 08-16-2007, 02:59 PM
b17a1db2's Avatar
the p72 and p73 rods are different. the stroke on both are the same, but the P73, which are type r rods, are a whole lot stronger. but i would say with 9200 revs constantly would decrease reliability in the long run. but going there seldomly wouldn't hurt anything IMO. but for confidence, having the p73 w/ arp bolts will hold up fine to that w/ no problem.
Old 08-16-2007, 05:40 PM
jcvelez360's Avatar
what made the p73 more stronger than the p72????
Old 08-16-2007, 07:01 PM
4g hatch's Avatar
p72's rotating assembly crank,rods is a little lighter. if your going with a mild all motor build either will do
Old 08-17-2007, 02:17 AM
b17a1db2's Avatar
more metal, stonger materials? idk, it's an "R" rod, so that's how i see it. i've seen stock type r block's withstand 9500 revs constantly w/ no problems.
Old 08-17-2007, 05:30 PM
4g hatch's Avatar
i stand corrected,the gsr's,type r's are the same. either will do great with arp rod bolts
Old 08-17-2007, 06:54 PM
b17a1db2's Avatar
Default Re: (4g hatch)
the gsr's and type r's aren't the same..
Old 08-17-2007, 08:33 PM
jcvelez360's Avatar
what do you thig about knifedge crank
Old 08-17-2007, 08:42 PM
4g hatch's Avatar
are u looking to get it done or is it already done,who did it. its a delicate thing and u want to make sure its right. for a mild build i wouldnt worry about it exspecially if u have a gsr crank since i think its around 4 pounds lighter than a hype r.
Old 08-17-2007, 08:52 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">i stand corrected,the gsr's,type r's are the same. either will do great with arp rod bolts</TD></TR></TABLE>
No, the rods are NOT the same.
Old 08-18-2007, 12:32 PM
jcvelez360's Avatar
Default Re: (Hybrid96EK)
ok.
i got other important question, its about the intake wich are the best that i can get.
aem, injen or what??????
please help me whit that one.
Old 08-19-2007, 06:12 AM
b17a1db2's Avatar
Injen or Fujita, or the nice carbon fiber intake from passwordjdm.com....
Old 08-19-2007, 03:02 PM
jcvelez360's Avatar
there is a comparaion betwen the thiferent intakes with gains on the dyno etc..??????
Old 08-19-2007, 03:13 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
No, the rods are NOT the same. </TD></TR></TABLE> Other than the bolt tensil strength, what is different? It's not weight, it's not material, it's not size, it's not shot peening, so what is it?
Quick Reply: max reving with p72 rods
