ls/vtec
Old Jan 22, 2005 | 08:43 PM
aznsins88's Avatar
Default ls/vtec
sorrie for the newbish question but does the B18B1 Block + B16A2 Head = LS/VTEC??? i really need to kno, thanks in advance!
~Eric
Old Jan 22, 2005 | 08:51 PM
shorto85's Avatar
Default Re: ls/vtec (aznsins88)
B18 nonvtec block plus any B series vtec head is considered a LS/VTEC
Old Jan 22, 2005 | 09:15 PM
aznsins88's Avatar
k thanks
Old Jan 22, 2005 | 09:26 PM
LsVtec98's Avatar
Default Re: (aznsins88)
i have the same set up that you are talking about. works fine.
Old Jan 22, 2005 | 10:32 PM
batmang yO!
Guest
Posts: n/a
a bit off topic but...
DAMN! no flaming here! im amazed
Old Jan 22, 2005 | 10:38 PM
djbutler007's Avatar
Default Re: ls/vtec (Beavis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beavis &raquo;</TD></TR><TR><TD CLASS="quote">a bit off topic but...
DAMN! no flaming here! im amazed </TD></TR></TABLE>
yeah i know, this must be the first time it hasnt happened
Old Jan 23, 2005 | 09:09 AM
dsmguy's Avatar
which head flows the best for the ls/vtec conversion?
Old Jan 23, 2005 | 11:53 AM
Ghettokracker71's Avatar
Default Re: ls/vtec (dsmguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsmguy &raquo;</TD></TR><TR><TD CLASS="quote">which head flows the best for the ls/vtec conversion?</TD></TR></TABLE>
Beat me to the draw on asking ! What other parts (if any) would be needed?
Sorry to be stupid/newbish,but I am a nissan guy and I am just now starting to learn about Hondas..
Old Jan 23, 2005 | 06:05 PM
ernald711's Avatar
Default Re: ls/vtec (Ghettokracker71)
https://honda-tech.com/zerothread?id=1118097
this'll help you out for a bulletproof bottom end
Old Jan 24, 2005 | 03:52 AM
TurboEH2's Avatar
well this is a bold statement, of course the ITR/CTR head flows the best, the B16A Head flowed 8% better than a B18C1 (GSR) Head on a flow bench. and normally the cheapest head you will find is the B16A so id go with that.
but if u work the gsr head, it flows crazy numbers.
Old Jan 24, 2005 | 03:54 AM
TurboEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghettokracker71 &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry to be stupid/newbish,but I am a nissan guy and I am just now starting to learn about Hondas..</TD></TR></TABLE>
there use to be alot of prep work for ls/vtec. but now alot of comapnies like Golden Eagle make the kit with the dowel pins, and the plugs, an fittings, lines, and sandwhich plate making it literally a bolt together conversion.
http://www.import-palace.com sells the golden eagle kit.
B18C5_EJ
Jun 4, 2006 11:15 AM
zenon8890
Dec 22, 2005 10:31 PM
Wolfwood
Jul 12, 2005 10:20 AM
xstalkrx
May 17, 2003 03:56 AM
88whitehf
May 8, 2003 07:36 AM
