Will i need bigger injectors if I go killer 2.0
I got my skunk2 stage 1's today and my next mod is probabally going to be a killer b18 block from Import builders w/ 12-12.5 compression. I plan on going hondata w/ bigger injectors, eventually. Will i be safe for a month or so using the stock gsr injectors and my vafc for tuning?
Re: Will i need bigger injectors if I go killer 2.0 (trustsi)
Ok, so i read tons of archived posts. The b20 injector is the same size as my b18c injector, 240. Since the b20 is a 2.0, im guessing I would not NEED the bigger injectors. Is this correct logic? Im still on my cx fuel pump, maybe Ill upgrade to a slightly larger honda pump. Whats a larger obd1 pump, b20,b18, etc?
