high compression d-series
Old 06-28-2004, 12:22 PM
dirtyturtle's Avatar
Default high compression d-series
i tried searching already and found nothing on this...
im currently pieceing together a 11:1 d16z6... im using PM6 piston and a milled head.. will the stock rods handle 11:1? or should i be looking into custom LS rods?
any other suggestions?
thanks
Modified by JDMPROject at 9:35 PM 6/28/2004
Old 06-28-2004, 12:50 PM
Mike K's Avatar
Default Re: high compression d-series (JDMPROject)
my friend has that same combo with a thin headgasket too, and he has no problem with stock rods.
Old 06-28-2004, 12:52 PM
Default Re: high compression d-series (Mike K)
hows does he like it?
what else has he done? any idea on whp?
thanks
Old 06-28-2004, 01:38 PM
RICE POLICE SIP's Avatar
I wanna know too... But it seems to me that the comp. might be to high for the rods... Better to be safe then sorry though....
Old 06-28-2004, 03:05 PM
Default Re: high compression d-series (Split Image Prez)
*forgot to mention it'll have a 9k redline*
Old 06-28-2004, 04:14 PM
Mike K's Avatar
compression too high for the rods? nah. it runs fine, for a sohc. i keep telling him to go dohc, but he likes being the underdog. it's in a 92 hatch and it's given a b16 swap a run for its money. if they made a 4.78 or 4.92 fd for the single cams, it would be great.
Old 06-28-2004, 04:17 PM
* B A N N E D *
chris_m's Avatar
They do have those final drives for sohc
Old 06-28-2004, 05:16 PM
Default Re: high compression d-series (alld16a)
i tried searching for final drives already, but with no luck, because i just had my tranny rebuilt, and i wanted it put in. but w/e...
thanks for the help mike. so you think the rods are strong enought for 11:1 - 11.5:1 w/ a 9000rpm redline? i also bought APR rod bolts, which should give the bottom end some more strength..
thanks for all the help guys..
Old 06-28-2004, 06:09 PM
* B A N N E D *
chris_m's Avatar
exospeed.com carries the ssr 4.7 , 4.9 d series hydro final drives
Old 06-29-2004, 12:32 PM
awesome thanks.. ordered the 4.9
Old 06-29-2004, 01:15 PM
Team 4's Avatar
Brett, either buy some LS rods, Crower bushings and have the rods shot peened, or buy a set of Eagles. The D series rods are THE weak link, especially at 9000rpm.
Old 06-29-2004, 01:28 PM
dsadas89das78934's Avatar
you will really be pushing it trying to rev a d16 to 9k... it is pointless, given there are no cams out there for the d16 that make power that high. the geometry of the bottom end of the d16 is NOT rev-friendly. i would go 8k max.
11:1 cr of stock rods is fine, my friend had a y8 running 12.6:1 on stock rods (before his oil pump exploded on him), and i personally have a d16 with pm6 rods at 10.5:1 compression.
Old 06-29-2004, 03:51 PM
Mike K's Avatar
talk to emerika on this board. he knows single cams real well.
Old 06-29-2004, 10:55 PM
im just going to take your advice chris, and go to malihat auto and hopefully get some LS rods... might as well pay the extra bux to play it safe...
*edit*
couple things arrived for me today
Old 06-30-2004, 08:32 AM
I really don't know
A D NOH's Avatar
dont you need to modify the LS rods to make them fit?
Also, how much more do the LS rods weigh than the d16 rods
nice picture of stuff
Old 06-30-2004, 10:19 AM
Default Re: high compression d-series (JDM EK9)
ya they do have to be modified... i need to order a rebushing kit from crower, get them shot peened and balanced.
Leland
10-01-2009 01:33 PM
UAFBOUND
07-22-2009 02:29 PM
Preludepradit
03-01-2007 04:39 PM
d16efsedan
31
02-12-2006 10:28 AM
Superdragr45
11
12-20-2004 01:37 PM
Quick Reply: high compression d-series
