help, ignition timing off after cam seal replacement
Old 06-10-2009, 01:59 PM
I like PIE
polishedturd's Avatar
Default help, ignition timing off after cam seal replacement
alright so after replacing my cam seal my ignition timing is off (2 degrees advanced) according to my timing light. i marked my distributor before removing it and set it back to where it was marked. when i installed the timing belt the cam gears where lined up and the crank pulley was lined up with the timing cover but i did notice a small amount of play where the crank pulley turns a little before the cams do. the reason for my concearn is that the car is tuned on s300 and i dont want to throw off my timing maps.
so i retarded the distibutor back 2 degrees to 16 at idle(where it was tuned) and am hoping everything will be all right. will it?
SouthSider13
10-15-2010 01:24 PM
Jap_Spec_Imports
12-20-2007 06:15 PM
00Red_SiR
02-10-2007 06:49 AM
Jorsher
10-24-2004 04:51 AM
donnjuan2point2
03-11-2004 10:49 AM
Quick Reply: help, ignition timing off after cam seal replacement
