Bowl blending, port/polishing- Is this Valve seat Ruined??
#52
Re: FV-QR (Combustion Contraption)
I should have known Don was old enough to see the fall of the Roman Empire.
BTW, Tim Radley, are you a professional head porter or did you just port your ITR head?
#53
Re: FV-QR (Phil M)
#54
Re: FV-QR (Tim Radley)
I wonder if I should feel like I'm 'cool' since I've met Vizard and have read a lot of his work. Although that mainly pertains to wedge motors (23degree are his forte.)
I typically stay as conservative as possible for my valve to throat ratio's if it is going on a street car. My customers seem happier with a fatter power band and more throttle response than having higher peak #s. Then again nearly all of my honda work ends up on street cars.
The O.P.'s bowl looked ok and should clean up with a simple valve job. In performance applications the seat is usually moved further toward the edge of the valve face and you'll run a narrower seat than what a p72/pr3 casting comes with. (excluding itr) Moving the seat out will hopefully bring back the lower angles of your valve job.
I think I've got a couple untouched castings in the shop still that I can measure what the stock valve to port ratios are to add to the mix. I use the same tools as CC.
You can't attribute all the weight shaved on a ITR intake valve just to the undercut stem... if you inspect them side by side with a gsr/b16 valve you'll notice that the face also gets machined down making the head even lighter/(weaker?) but this is also done because it helps flow too.
#56
Re: (b20vtech)
Originally Posted by b20vtech
and i also did some measurements, throat is at 87%
Modified by b20vtech at 9:33 PM 11/13/2008
Modified by b20vtech at 9:35 PM 11/13/2008
87% of the valve diameter or of the 45 seat angle outer diameter?
