Bowl blending, port/polishing- Is this Valve seat Ruined??
Bowl blending on a GSR head, kinda touched the copper/bronze seat there a bit, wondering if this is still ok.
It's kinda hard to see, but I tryed my best!! https://i242.photobucket.com/albums/...g/DSC03685.jpg https://i242.photobucket.com/albums/...g/DSC03679.jpg https://i242.photobucket.com/albums/...g/DSC03680.jpg https://i242.photobucket.com/albums/...2valveseat.jpg Modified by b20vtech at 10:05 PM 11/5/2008 |
Re: Bowl blending, port/polishing- Is this Valve seat Ruined?? (b20vtech)
Who cares if it's ruined or not by the porting, you should get a valve job anyways since your seats are already pitted.
Re: Bowl blending, port/polishing- Is this Valve seat Ruined?? (ruffrhyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder »</TD></TR><TR><TD CLASS="quote">Who cares if it's ruined or not by the porting, you should get a valve job anyways since your seats are already pitted. </TD></TR></TABLE>
well i was worried that i might of nicked it into far that maybe i couldn't get a good valve job to fix it. |
someone who is concerned with structural integrity would be concerned. I dont have an answer for you but hopefully some of the real head porter will chime in and help you out https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Bowl blending, port/polishing- Is this Valve seat Ruined?? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
someone who is concerned with structural integrity would be concerned. I dont have an answer for you but hopefully some of the real head porter will chime in and help you out https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> yes sir, i am waiting for those guys to chime in... https://honda-tech.com/forums/images...es/emdgust.gif |
FV-QR
It will be fine for what it is. A pitted stock VJ. You wont see much just blending it into the throat
Re: FV-QR (Combustion Contraption)
basically i just want something similar to the type r.
Re: FV-QR (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">It will be fine for what it is. A pitted stock VJ. You wont see much just blending it into the throat</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">basically i just want something similar to the type r.</TD></TR></TABLE> See what Steve is hinting at? Get a Type R VJ or better to get the best bang for your buck:thumbup: |
the seat is fine but take it to a machine shop and have a valve job done.
30-45-65 is what the ITR comes with. if you want add a small 75 cut to the 30-45-65 and it will pick up .400 & .500 lift flow. by just blending the bowl with the stock VJ you wont see much for gains. working the right places of the SSR will liven things up a bit. |
Re: FV-QR (ruffrhyder)
See what Steve is hinting at? Get a Type R VJ or better to get the best bang for your buck:thumbup: </TD></TR></TABLE> yes, i just pm Steve about the VJ https://honda-tech.com/forums/images/smilies/emwink.gif |
Amazingly, there's good info/help has been provided in this post.
YES WE CAN / CHANGE. FO DA WIN!!!! Sorry Joe Da Plumma...your 15minutes of fame are over--it's JOe da porta time!!! |
Re: FV-QR (Master of the Universe)
a decent valve job will fix your problem. nothing to worry about, that is so minor as to not even be an issue. take your valves and that head to a decent shop and let them do the work. it will come back quite a bit better than a hype r valve job.
Re: FV-QR (idrivesideways)
Bah. measure the throat on the intake and exhaust. As long as its not to big for the valve. Other wise if its too small you can go with 1mm over valves to make sure the valve has something to seat to. This is what i do with my port jobs https://honda-tech.com/forums/images...es/emsmile.gif
Re: FV-QR (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Bah. measure the throat on the intake and exhaust. As long as its not to big for the valve. Other wise if its too small you can go with 1mm over valves to make sure the valve has something to seat to. This is what i do with my port jobs https://honda-tech.com/forums/images...es/emsmile.gif</TD></TR></TABLE>
what size of the throat is consider too big for the valves? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote"> what size of the throat is consider too big for the valves?</TD></TR></TABLE>
Joe Da Plumma wants to know too, David Vizzard already knows. Throat/Valve Ratio fo da win!!!! |
what size of the throat is consider too big for the valves?</TD></TR></TABLE> Depending on application, throat to valve ratio should be around .85-.9:1 https://honda-tech.com/forums/images/smilies/emthup.gif Or so I've read and been told several different porters https://honda-tech.com/forums/images/smilies/emthup.gif |
FV-QR
Does 2V shallow chamber wedge head using cam w/ .800" lift want a different throat % than a down draught 4v using .470" cam?
Sorry jus here 2 lurn. Hope someone gives up da info out of da goodness of der heart! |
The simple answer is there is no simple answer.
Don't fool yourself with a "ratio." One is not limited in tweaking just the throat size. <FONT SIZE="8">JO PORTA/PLUMMA FO DA WIN!!!!!</FONT> |
Re: FV-QR (Tim Radley)
Originally Posted by Tim Radley
92% is generally considered the absolutely largest. I would not go over 88% myself. |
Re: FV-QR (DonF)
Originally Posted by DonF
For what size valve and port? Turbo or NA? Drag racing or road racing?
I would base it more on the profile of the port rather than 'size'. For NA or turbo i would not go over 90 regardless of application, but everyone does it there own way. |
Well i'm talking percentage of valve.
Originally Posted by Combustion Contraption
even when the bench does not show an improvement.
Re: FV-QR (mar778c)
Originally Posted by mar778c
Why? what are the implications? |
