Another B20VTEC Build in progress (85x87.2mm)
Old 11-14-2008, 03:33 PM
ProMotive's Avatar
Default Another B20VTEC Build in progress (85x87.2mm)
Selling everything and going K20, PM me if you need anything from the list below
Thanks!
-Wiseco Pistons K567M85 $425
-Eagle GSR/ITR Connecting Rods with 3/8" ARP Rod Bolts $275
-Jun III Cams $625
<u>11/14/08 Update:</u> Pistons, Rods, Oil, & Water Pump Arrive
Modified by ProMotive at 6:20 AM 11/15/2008
Old 11-14-2008, 04:27 PM
flesh199's Avatar
what kind of intake this engine will run?
Old 11-14-2008, 04:49 PM
Agnom's Avatar
Default Re: Another B20VTEC Build in progress (ProMotive)
What is your choice of intake manifold and exhaust header?
Old 11-14-2008, 04:50 PM
New User
jake512's Avatar
whats up man.. make sure you get a good breather kit for the block... many people fail to do this and then they end up with a cracked block... good luck with your build
Old 11-14-2008, 10:08 PM
All Motor Mentor
00Red_SiR's Avatar
Default Re: Another B20VTEC Build in progress (jake512)
a cracked block.... and how does this happen from not running a breather kit?
Old 11-14-2008, 10:54 PM
98DC2R's Avatar
Default Re: Another B20VTEC Build in progress (00Red_SiR)
Or a sleeved one for that matter??? Did you ready the parts list?
Old 11-14-2008, 11:05 PM
mnskateboarder's Avatar
Default Re: Another B20VTEC Build in progress (98DC2R)
looks like a good plan for a build. which header do you have in mind?
Old 11-15-2008, 05:23 AM
ProMotive's Avatar
Default Re: Another B20VTEC Build in progress (mnskateboarder)
I knew I was forgetting something
Not sure yet on the header choice, I have a JDM ITR 4-1 already on the B18C1 that I might use until I can find a good deal on a used better unit.
I'm not sure what I'll be using for IM and TB - I already have a Edelbrock 65mm TB, but I might pick up a Ported ITR TB & Ported ITR IM.
Old 11-15-2008, 07:28 PM
ware's Avatar
Old 11-17-2008, 04:05 AM
00b20vtecoupe's Avatar
thats not really a b20vtec build with a gsr crank. put an ls crank in man. 85x89 is the way to go.
Old 11-17-2008, 04:06 AM
but thumbs up to the evans tuning ill be going there about that time in march to retune my b20 vtec beast hoping to make 240's. good luck
Old 12-03-2008, 06:57 AM
ProMotive's Avatar
Yea I realized that after I put up the ad. 2.0L GSR is more like it
Old 12-03-2008, 06:58 AM
ProMotive's Avatar
Came across a good deal on a K20A2 swap, so everything's going up for sale. Still getting KPRO tuned at Evans though
boosted1996
04-29-2017 10:48 PM
CivicSI2009
04-28-2009 03:21 PM
swpdb16
01-31-2008 11:41 AM
acydphryck
04-25-2004 11:08 PM
GRIMEY.STREET.RACER
01-06-2003 06:00 AM
Quick Reply: Another B20VTEC Build in progress (85x87.2mm)
