***Official All-Motor Stock Sleeve B20VTEC Thread***
#1251
#1252
re: ***Official All-Motor Stock Sleeve B20VTEC Thread***
In the making.
Jdm b20b
96 spec gsr head
Removing butterflys and porting out intake
11:1 arias pistons with shotpeened rods
Getting all balanced and getting around 2lbs taking out of crank
12lbs flywheel with soon stage 3 clutch
EBay header
H22 injectors with 255 walbro.
Chipped ecu with obd1 conversion (going in a crx hf)
Getting block guard cam gears and type r pulley and arp everywhere
Gsr tranny non-lsd
3 in exhaust straight pipe all the way
Any comments to help that would be great
I am planning on definitely hitting 12s hope low but we will see should be done in 4 to 6 months taking time make sure right cause it will also be a daily driver has to last
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
#1253
In the making.
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
#1254
In the making.
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
#1255
I also was wondering from anybody would it be okay to use a b16 oil pump instead of a gsr? Would it be the same oil pressure or would ot be safer with a gsr one? Thanks for the help
#1256
Yeah I was really curious about that but limited on cash that's y I chose to DIY method but if I could find one for cheap I would get it or a skunk2 proseries
hit up BlueR.. he has brand new p72 Oil Pumps. for a better price then i see anywhere else. and shipping is fast
#1257
In the making.
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
Jdm b20b
96 spec gsr head
EBay header
Gsr tranny non-lsd
sounds like my build except im running je 11:1 pistons with eagle rods and im running skunk 2 tuner 1 cams and smaller exhaust im hoping to hit atleast the 190 whp mark
#1259
#1260
my last set up was a b16 with 11.5.1 comp je pistons and eagle rods 440cc injectors and srpings and retainers my best time on bold as hell street tires was a 13.9 at 105mph my times all sucked up until the 1/8 mile
#1261
[QUOTE=dirtyharryhatch;42010961]anyone know piston's around the RS ITR spec price range that yield a bit more compression?[/
how high of a compression you trying to run the rs pistons yield you 12.0:1-12.5:1 with the head decked .005
#1265
A Digital Frontier
#1266
decided to go with the competition stage 2 clutch kit with the lw fly wheel . anyone else running this clutch ?
i was gonnna go with the ACT but people saying the pedal is stif and they recommended me the competition =]
#1267
#1268
Cant wait until my set up is done!!
JE 12:1 84mm pistons
Manley H beam Rods
Acl bearings
Arp rod bolts and head studs
RC 310 injectors
Skunk2 pro series manifold
ITR throttle body
Mugen 4-1 Header
Gsr port n polished head
Skunk2 pro series Cam gears,Valvesprings&ti retainers
Brian Crower Stage 2 camshafts
3 angle valve job
ACT 6 puck sprung clutch HD pressure plate
Type R flywheel
hondata s200
OEM b20 head gasket
Aem fuel rail&fpr
Manley H beam Rods
Acl bearings
RC 310 injectors
ITR throttle body
Mugen 4-1 Header
3 angle valve job
Type R flywheel
hondata s200
OEM b20 head gasket
Aem fuel rail&fpr
#1269
why are people telling me not to run over 12.1 compression but nearly everyone in this thread is at or over 12.1 compression?
#1271
Manley H beam Rods
Acl bearings
RC 310 injectors
ITR throttle body
Mugen 4-1 Header
3 angle valve job
Type R flywheel
hondata s200
OEM b20 head gasket
Aem fuel rail&fpr
Manley H beam Rods
Acl bearings
RC 310 injectors
ITR throttle body
Mugen 4-1 Header
3 angle valve job
Type R flywheel
hondata s200
OEM b20 head gasket
Aem fuel rail&fpr
#1272
#1274
wtf people say so many diff things. these guys in my b20vtec thread were both saying how i was going ot blow my motor running 12.5 pistons. Im going to use hondata s200 to tune with a reputable tuner. 92 octane is the highest around here. So confused.
#1275
we advised you not to run that high on that low octane fuel you know what your tuner is going to do he is going to retard your ignition timing t so you dont detonate while running that high of a compression with that low of a octane hence since he is going to do that your going to lose some hp and your power is going to be the same as if you ran a lower compression so why run that high of a compression and risk it if it gives you no gain
