Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
04 TSX Vtec controller?
Old Jul 20, 2011 | 07:23 PM
2fast4urass's Avatar
Icon2 04 TSX Vtec controller?
Now I just bought my tsx it's fast I just need to hit Vtec at lower rpms now my question is which Vtec controller would be best? I have an apexi v-afc2 that I ran on my DC2 would it work for my 04 6spd tsx?
Old Jul 20, 2011 | 09:18 PM
xero_xero's Avatar
Default Re: 04 TSX Vtec controller?
i have a feeling the obd2 ecu is going to kick your ****. i believe it will cel into limp mode.
Old Jul 20, 2011 | 10:08 PM
HAMOTORSPORTS's Avatar
Adjusting VTEC to an earlier RPM isn't going to work too well for you without also adjusting the cam angle at the same time (VTC), and then also fuel and ignition timing. I wouldn't recommend installing a "VTEC controller"
Old Jul 20, 2011 | 10:49 PM
xero_xero's Avatar
what is the variation of timing, on say the k24, at vtec engagement (timing at low cam just before and timing at high cam after engagement)
Old Jul 21, 2011 | 06:10 AM
I think vtec starts to engage at 6k but am not sure let me check today after work, thank you every
One who's responding
Old Jul 21, 2011 | 06:37 AM
It is variable depending on engine load, etc..
Old Jul 21, 2011 | 02:19 PM
JoeScro's Avatar
I think the factory setting is at 7k or even 7500rpm.
Old Jul 26, 2011 | 09:49 AM
Jdm Oz's Avatar
crossover is at 6000rpm on the k24a3
Old Jul 29, 2011 | 02:22 PM
What grade of fuel is best that I use , my brother has a 04 accord k24 5spd he uses grade 87 I have an 04 tsx k24 6spd I've been using 91 would it be ok if I down grade to 87 or are there any side effects???
Old Jul 29, 2011 | 07:12 PM
gsrvtec2000's Avatar
vtec kicks at 6k. redline is at 7k, maybe 7.4k but thats CUTTING IT!
Old Aug 3, 2011 | 10:22 PM
tsxpert's Avatar
Just get your ecu reflashed by hondata!!! It's only $300 plus shipping. Steal and Deffinetly worth it!! Vtec's lowered to 5000rpm's and redlined at 7600rpms. Best bang for the buck. VTec controllers are for bseries.
Old Aug 7, 2011 | 10:06 AM
Icon2 Re: 04 TSX Vtec controller?
Ok now I just got one more issue my " vsa /!\ " light is on I changed my brake but they still won't work and yes I naught correct light bulbs 7443, what can I do ???
Old Aug 7, 2011 | 02:35 PM
our motor are meant for 91 or premium for whatever state you're in. lowering the octane would basically make your car weaker. I dont know if there are any harmful side effects, but i do know you wont feel as much power.
Old Aug 7, 2011 | 02:58 PM
Na its cool ill just stick to premium thanks to all that have helped out
Stricly JDM
Jan 8, 2009 03:43 PM
tvman
Oct 31, 2005 07:08 PM
austrian type-R
Jul 31, 2002 05:57 AM
RevIllusions
Feb 15, 2002 11:08 PM
tr4il
Nov 25, 2001 07:58 AM
