VTEC controllers possible on i-VTEC
Old Jul 30, 2002 | 09:17 AM
austrian type-R's Avatar
Default VTEC controllers possible on i-VTEC
can the usual Vtec controllers be used on the new iVTEC engines. Or is there no chance to controll VTEC with Aepxi VAFC or Fields?
[Modified by austrian type-R, 7:19 PM 7/30/2002]
Old Jul 30, 2002 | 09:22 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: VTEC controllers possible on i-VTEC (austrian type-R)
Good question, if the soleniod's the same voltage it should work on the cam switchover for lift but not the variable cam timing portion.
Old Jul 30, 2002 | 09:25 AM
DutchITR1689's Avatar
Even if it works, I don't think it's good. Because the ECU has to switch to the VTEC fuel map too when VTEC is engaged.
Old Jul 30, 2002 | 09:34 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: VTEC controllers possible on i-VTEC (DutchITR1689)
You can compenstae for that by richening up the fuel curve across the rpm range where you lowered the x-over. At least that's how it works on our cars.
Old Jul 30, 2002 | 09:36 AM
Default Re: VTEC controllers possible on i-VTEC (newt2)
I know, but it's not optimal. How about ignition timing and such?
Old Jul 30, 2002 | 09:38 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
That's what standalones are for. Unfortunately I don't think there's a standalone that can do i-VTEC or VVTL-i engines yet. The dynamic cam timing would be a bitch to program for.
Old Jul 30, 2002 | 10:17 AM
Chubz's Avatar
No you can't use a VAFC on IVTEC equipped cars. Go Apex-I's website, they explain why.
Old Jul 30, 2002 | 10:38 AM
85pokey's Avatar
Some guy on the clubrsx board got the apexi vafc to work on his rsx-s- he had the type-r(dc5r) cams installed and wanted to take advantage of them- he dynoed the car and the results weren't too impressive- if i remember right he was at or below stock rsx-s hp/tq numbers-- but this was before any major tuning and i believe he was getting other parts for the engine as well- u could try doing a search on there - he is the only one that i have heard of doing anything like that
Old Jul 30, 2002 | 11:13 AM
ITRinEJ1's Avatar
Default Re: VTEC controllers possible on i-VTEC (85pokey)
the new power enterprise vtec tachometer is usable for i-VTEC/RSX
Old Jul 31, 2002 | 05:43 AM
Default Re: VTEC controllers possible on i-VTEC (ITRinEJ1)
link?
Old Jul 31, 2002 | 05:57 AM
Willard's Avatar
https://honda-tech.com/zerothread?id=242397
2fast4urass
Acura TSX
13
Aug 7, 2011 02:58 PM
tvman
Oct 31, 2005 07:08 PM
genetsang
Aug 4, 2003 06:08 PM
3700 Vtec
Feb 27, 2003 12:08 PM
tr4il
Nov 25, 2001 07:58 AM
