98 TL with EGR issues
Re: 98 TL with EGR issues (acnup98)
I do believe Acura has an EGR valve kit for that car.
It requires opening the valve assy. drilling out all the **** and replacing the gaskets and inserting a new tube into the assy.
Call 1-800-825-1550 and get a quote
Re: 98 TL with EGR issues (ITR640)
P0401 is on because low flow of EGR system First, remove the valve itself. Try to clean out the vacuum port - Soak with Carbon cleaner for a while then ream it with a flexable cable. Start the engine to see is ther strong vacuum or not (Plave the finger over the vacuum port to feel it).
If ther is enough vacuum. Reinstall the valve. Clear the code and do drive cycle to confirm the repair.
Good luck.
Good luck.
Re: 98 TL with EGR issues (ataiko)
Grande Thanks, Ataiko!
Is this a DIY repair that is going to make me cuss? I used to to alot of DIY's to my previous cars but this one is dealership spoiled. I've priced parts and got a couple of quotes but I can't see a shop repair right now. Is this do-able?
THX, ITR640!
I have gotten a few prices and DIZAMMMM!!... they're expensive. Can you give me a play by play on this project. The situation is bad enough. I don't wanna make matters worse.
acnup98
acnup98
Dc4LsTeG
01-12-2012 03:21 PM
hollywood28601
12-27-2010 11:09 AM
markbradford
04-09-2004 02:49 PM
