P1457 Dummy Code
Old Nov 1, 2007 | 11:28 AM
EvilDC's Avatar
Default P1457 Dummy Code
I got this code in my 98 teg ls. The codes been of and on for about a year now. Just lately tho I've started to get a pretty hard miss on take offs and a slight miss in low (500-1500) rpms in just about every gear. I replaced the solenoid back by the tank along with the valve and the solenoid on top of the canister. I also pressure checked all the vacuum line and they tested good. So if you guys could give me anymore ideas id appreciate it thanks.
Old Nov 1, 2007 | 11:41 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: P1457 Dummy Code (EvilDC)
seems like you did everything necessary for that code...P1457 is a failure in one of the evap system solenoid valves. there are 2 culprits, the vent control valve & the 2 way bypass valve. they crap out due to corrosion/contamination from water seeping into the valves.
if you replaced thoser then i would have the ecu cleared...don't just pull the battery cable but take it someone like autozone to actually completely erase the ecu
Eliot Tapia
May 27, 2019 06:18 PM
strum456
Jan 15, 2013 03:43 AM
vrrodri
May 6, 2011 04:34 PM
"93XSi"
Dec 24, 2005 09:22 PM
hondadriver
Oct 30, 2004 03:18 PM
