High Idle and Fluctuating Idle. IACV and ECU was already replaced by Dealer?
Old Feb 17, 2009 | 03:16 PM
immalooser's Avatar
Default High Idle and Fluctuating Idle. IACV and ECU was already replaced by Dealer?
I'm having a strange issue with my 06 Base Manual. I don't have any mods whatsoever. The car is completely stock. Now i'm having high idle and fluctuating idle on my car when i'm driving and at a stop. Also when i'm driving i am getting alot of rev hang.
Now here is the issue. When i first noticed this problem back in November, i searched on here and crsx, and found a article on how to clean my IACV. I followed the instruction and that didn't work. Because my car is still under warranty, i brought it into the dealer and they replaced my IACV. That fixed the problem for about 2 -3 weeks and then the problem came back. I brought it back to the dealership again and this time, they replaced the ECU. I drove it for about a day and the problem came back.
Right now, the dealership and I are both stumped as to what the problem is. I don't believe it's a vacuum leak, otherwise the idle should be consistently high which it is not. If anybody have any suggestions as to how to fix this problem please reply.
Old Feb 17, 2009 | 06:13 PM
nahonda04's Avatar
Surje.motorsports
Default Re: High Idle and Fluctuating Idle. IACV and ECU was already replaced by Dealer?
Tps sensor bad? Maybe!!?? Dunno. That is the only other thing i can think of if the ecu has been replaced and the iavc has been cleaned/replaced.
Old Feb 17, 2009 | 07:10 PM
eMpAtHy's Avatar
if it's under warranty, then it's the dealers job to fix it. bring it back and have them keep it until it is fixed. enjoy driving the tsx/tl or any other nice loaner they will give you.
Old Feb 17, 2009 | 07:19 PM
DaveSi677's Avatar
True that!!! You shouldn't really be wasting your time if its under warranty... make them do it its what a warranty is for!!!!!!!!!
Old Feb 17, 2009 | 08:52 PM
johnnynguy3n's Avatar
You check the oil? I know you said you're stock, but that idle fluctuating happened to me too, but I fixed it by changing the oil because I sucked up water from my cai.
Old Feb 17, 2009 | 09:09 PM
immalooser's Avatar
I know, it's already been at the dealer 3 times in less than 3 months for the same issue. This is going to be the fourth time. The last time they took it they had it for 3 weeks. The car is going back this friday, i just wanted to get other opinions.
Old Feb 17, 2009 | 09:30 PM
eMpAtHy's Avatar
if it keeps going back for the same problem, bring up the lemon law. each state has a different lemon law, so read up on it.
http://www.lemonlawamerica.com/
Old Feb 18, 2009 | 05:23 AM
josh's ep3's Avatar
Function > Form
Yeah I would definitely drop it off and tell them not to call me until it's fixed. Or you could mention to them that maybe you just got a bunk motor and they should swap it out... and for your trouble... they should prolly just upgrade you with a new little Type-S motor hahaha lol.... but forreal.
crxguy406
Sep 10, 2015 03:56 AM
PhatwhipsJDMkits
11
Apr 7, 2009 05:51 PM
mikeunreal2
Mar 29, 2006 09:27 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
LSpimpTEC
Apr 28, 2003 11:29 PM
