Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
alignment problem
Old May 3, 2010 | 12:17 PM
smd6942's Avatar
Default alignment problem
So one of my tires got messed up and i went to get a new tire but when i drove off i noticed that my car starts to lean to the right. I saw the guy balance it and everything but it leans anyways. Also, how much do the wheels have to be torqued to because when they put the tire back on they just tightened it back on and could this be part of the problem.
Old May 3, 2010 | 12:22 PM
da9leo's Avatar
I <3 DA's
Default Re: alignment problem
you probably need to get it aligned, take it to a reputable shop that show before and after specs
if the wheel wasnt torqued right, it would shake and wobble
Old May 3, 2010 | 12:27 PM
K5^'s Avatar
K5^
Brand New
The torque specs are 80 ft-lbs. I think you'd have worse problems other than alignment if they were not torqued down properly.
^I agree.
Old May 3, 2010 | 12:29 PM
smd6942's Avatar
could i get an alignment under warranty or you think i should just go to a shop. Also, by the shop just tightening the wheel it should be fine because i was always told to torque the wheels.
Old May 3, 2010 | 12:35 PM
da9leo's Avatar
I <3 DA's
no warrantys dont cover that, you need to do it
Old May 3, 2010 | 12:37 PM
smd6942's Avatar
ok thanks for everything i'll start looking into shops
Old May 3, 2010 | 12:46 PM
da9leo's Avatar
I <3 DA's
but make sure to ask for a print out of before and after to actually check if they did anything or not
a local place i took my car to tried charging me without actually doing anything
Old May 4, 2010 | 01:48 PM
BakerIsBored's Avatar
Seems like this generation just likes to pull to the right. I had to get mine aligned and even still it ever so slightly pulls to the right.
netfreak
Suspension & Brakes
Nov 8, 2010 03:35 PM
beater90accordlx
Feb 14, 2005 03:21 PM
DI9ITAL
May 8, 2003 11:33 AM
Freelance-GSR
Aug 4, 2002 12:22 PM
hondafrk
Feb 22, 2002 06:52 AM
