what the hell is the problem here
Old Oct 29, 2002 | 01:02 PM
andrewasf77's Avatar
Default what the hell is the problem here
hey guys, looking for some help. i have a 97 itr and i am having a problem with the engine losing power at 7100 rpm. im not sure what the problem is, it almost feels like is hitting the rev limiter or misfiring. i would appreciate any comment, or anybody who know a good shop in gainesville, fla. thanks guys!!
--andy--
Old Oct 29, 2002 | 01:04 PM
Reid's Avatar
Global Moderator
Default Re: what the hell is the problem here (andrewasf77)
Try taking it to the dealership.
Also it's not easy to diagnose problems when you give no information as to the scenario from which the problem stemmed.
Nate B's Avatar
I would start with the basics like checking oil, spark plugs, fuel pressures, etc...hopefully it's something simple like one of those problems
Old Oct 29, 2002 | 01:06 PM
Default Re: what the hell is the problem here (TypeR#1111)
could it be a distributor problem?
Nate B's Avatar
I don't know, have you checked for spark? Or checked your timing?
[Modified by TypeR#1111, 2:06 PM 10/29/2002]
i had the timing and ignition checked, its seems that all is ok there
Old Oct 29, 2002 | 01:07 PM
Default Re: what the hell is the problem here (Reid)
sorry reid
Old Oct 29, 2002 | 01:08 PM
Dave-ROR's Avatar
need real information to try to figure this out.
hitting the rev limiter and misfiring never felt the same to me, describe exactly what happens, when it does it, what the conditions are, etc.
Old Oct 29, 2002 | 01:09 PM
Reid's Avatar
Global Moderator
sorry reid
So this problem just happened one day out of the blue?
If so I'd change your cap, rotor, and plugs while you're at it. Might as well change it all at once.
Jsracingintegra
Guest
Posts: n/a
Change your fuel filter
Old Oct 29, 2002 | 01:10 PM
Default Re: what the hell is the problem here (Dave-ROR)
well it does not do it all the time, very spuratic. at 7100 rpm the engine gets weak, like its cutting in and out. everything is fine up until that point though, nothing at low rpm's. i guess imma take it to the dealer and stop messing around, i was just looking for a little guidance.
Old Oct 29, 2002 | 01:11 PM
Reid's Avatar
Global Moderator
Change your cap, rotor and plugs and see if that helps anything.
Old Oct 29, 2002 | 01:12 PM
thanks reid
Old Oct 29, 2002 | 01:19 PM
thanks guys, that why ht rules, itr owners helping other itr owners
Old Oct 29, 2002 | 01:28 PM
Bbasso's Avatar
check the timing, get a gun and take a look.
maybe the valves are outta wack- or the cams were ground flat?
make sure the TB is open and clear.
what kinda intake do you have, is it working and clean?
does it happen while in gear and in nutreul too?
Do you have any kinda exhaust, is it in working condition? not bottomed out ?
Just ask yourself the common sense questions.
also does you gas cap fit well?
Old Oct 29, 2002 | 01:30 PM
Default Re: what the hell is the problem here (Bbasso)
everything on the car is stock, could possibly be a problem with the valves, the previous owner had some valves replaced because he bent some over-revving
Old Oct 29, 2002 | 06:18 PM
#417R's Avatar
Get the exhaust checked out, sounds sort of like a cat problem.
Old Oct 29, 2002 | 06:39 PM
ITR21's Avatar
Default Re: what the hell is the problem here (Y2KITR)
not to me. someone already mentioned this but check your oil. If your oil is low vtec will cut in and out due to the lack of oil pressure. The next thing i would check is your plugs for sure, i had bad plugs in my car at one point and i was getting all sorts of missfireing. from the breif description it sounds like ignition or fuel which doesnt exactly narrow it down to anything speciffic just keep checking things.
[Modified by ITR21, 3:41 AM 10/30/2002]
Old Oct 29, 2002 | 06:45 PM
Nameless RB26's Avatar
Default Re: what the hell is the problem here (ITR21)
You may have a midget stuck in the timing belt.
Old Oct 29, 2002 | 07:09 PM
R-1303's Avatar
Default Re: what the hell is the problem here (Nameless)
ITR 21 put it the best, check your oil...vtech runs off of oil pressure, if you were going up hill or around a corner it would cause you car to have a bog feeling and climb out of vtech....check you cap and rotor also..and plugs..what i would suggest is that you check the oil first, its sounds like a oil problem...
Old Oct 29, 2002 | 08:29 PM
Paste's Avatar
Loved
Default Re: what the hell is the problem here (R-1303)
sell the car to me , check your oil, AND replace oil filter
Old Oct 29, 2002 | 08:57 PM
H-PIMP's Avatar
Default Re: what the hell is the problem here (paste)
Sounds like crank position sensor, my car did the same. After replacing the sensor and resetting the ECU the car has been fine ever since.
kpxhonda
Oct 5, 2004 06:47 AM
deviant94ex
Jan 2, 2002 05:30 PM
mattymatt
Jun 28, 2001 12:50 PM
