Stumbling!
Old Jun 28, 2001 | 04:23 AM
mattymatt's Avatar
New User
Default Stumbling!
My car seems to stumble a bit in 1st and 2nd when accelerating at 1/3-1/2 throttle to 3000 rpm. I'm uncertain as to whether or not this problem started after I changed the plugs to Bosch Platinum +4's (I'm going to change them back to NGK coppers, but I can't seem to get a hold of 'em). I also noticed that after I changed the plugs, the engine sometimes clunks when it turns over from a cold start...
I thought the problem might be a ignition timing problem / spark plug problem. Any suggestions?
Thanks in advance,
Matt
Old Jun 28, 2001 | 06:30 AM
clockworks's Avatar
Default Re: Stumbling! (mattymatt)
I'm having the same problem, but only after the car has had a chance to get hot. So far I've replaced all the ignition components except for the ignition module. It seemed to help a lot. I'm in the process of checking the entire fuel system now. I doubt that the problem started after you changed the plugs, but I like NGK coppers the best.
Greg
Old Jun 28, 2001 | 06:40 AM
mattymatt's Avatar
New User
Default Re: Stumbling! (clockworks)
Ya, the problem occurs when the engine is warm...
Let me know if you've pinpointed the problem. I'm going to change the plugs and wires, and fix the ignition timing, hopefully that'll help.
So by ignition components, does that include the coil?
Old Jun 28, 2001 | 06:46 AM
clockworks's Avatar
Yeah, the coil can cause it when the engine is hot, so I replaced it; it didn't cure the problem though. I have an MSD box and a blaster coil that I put in like a year and a half ago, so I didn't think that that was the problem, and I guess it wasn't.
Greg
Old Jun 28, 2001 | 06:52 AM
blaze's Avatar
i had a problem like that but it was related to my o2 sensor. i didn't get any codes but after replacing the o2 sensor the "stumbling" went away.
Old Jun 28, 2001 | 07:10 AM
clockworks's Avatar
Default Re: Stumbling! (blaze)
Do you think that my A/F meter is drawing too much current? I have a new O2 sitting around, so I guess I'll replace the primary one.
Greg
Old Jun 28, 2001 | 07:32 AM
mattymatt's Avatar
New User
Let me know how that works out for you when you change it.
How hard is it to change the O2 sensor? And how much for the part? Alternatively, how much would it cost for me to take it to a shop?
Old Jun 28, 2001 | 08:01 AM
FSTASNTZ's Avatar
Last time mine did that, I replaced the front 02 sensor before it got any better. So far, so good.
Jason
Old Jun 28, 2001 | 11:23 AM
clockworks's Avatar
It's easy, you just need an O2 sensor socket and a soldering iron for the universal replacements; the parts from the dealer (with harness') are a lot more I think. One wire O2's are like $20, heated ones are more expensive. It might just be the answer, because I got a secondary O2 check engine code. I'm gonna replace it tonight, I'll tell you how it goes.
Greg
Old Jun 28, 2001 | 12:50 PM
clockworks's Avatar
Default Re: Stumbling! (Jonesy69)
yeah, cap and rotor are new.
Greg
jdm.fanatic
Sep 26, 2009 05:14 AM
CARflyGUY
May 30, 2007 07:20 AM
A.E Motoring
Aug 16, 2006 07:04 PM
bumbaiulearn
11
Mar 28, 2006 12:49 AM
ThatRicerDaniel
Feb 3, 2003 10:53 AM
