Weight of different flywheels
can anyone give me a list a weights for the flowing flywheels.
*jun
*toda
*stock ITR
*clutch masters
please feel free to ad others to the list to.
*jun
*toda
*stock ITR
*clutch masters
Re: Weight of different flywheels (AssPenny)
ACT xact superlite cromoly is 8.8lbs
Re: Weight of different flywheels (Charlie Moua)
ya know what... i never even hear about many people running thoes... how do you like it?
Re: Weight of different flywheels (RTW DC2)
Dont just consider the weight. You need to take into consideration the rotational mass - if flywheel x weighs 9 lbs but retains 65% of its mass at its hub, it will spin faster than flywheel y which might weigh less, but with worse weight distribution.
Re: Weight of different flywheels (FAST4DR)
don't bother Dave... everyone knows that the total weight is the MOST important thing when looking to buy a flywheel.
Darth ModerVader
Suspetise...
1 Post
Re: Weight of different flywheels (Padawan)
I'm curious, what exactly are the differences between chromoly and aluminum as far as flywheels are concerned? Is chromoly stronger than aluminum? Can one or both be resurfaced? I'm assuming chromoly is more expensive than aluminum, but I'm just basing that on the prices of what I think are available (ex. Toda more expensive than Jackson Racing).
[QUOTE]*JUN - 4.3 / 4.6 kg (9.46 /10.12 lb.)
*Toda - 4.1 kg (9.02 lb.)
*stock ITR - ~15 lb.
*CM/Fidanza - 7.5 lb.[/QUOTE
anyone know the stock weight if the B16 and B18B flywheel? just need to compare it alittle.
I have the Spoon flywheel.
4.2 kg = 9.24 lbs
"For the ultimate in street and strip performance, choose the Spoon Sports Lightweight Flywheel. Weighing in at 4.2kg compared to the factory 6.9kg. This flywheel is not TOO light, so you won't loose off the line torque. Help your engine spin freely while making power with one of these Spoon flywheels. Already pre-balanced and comes with a new pilot bearing and flywheel bolts...simply the BEST. Will fit all B-series transmissions, cable and hydraulic. "
4.2 kg = 9.24 lbs
