vtec
Old Nov 8, 2004 | 07:08 AM
b16racer23's Avatar
Default vtec
i just swap a jdm itr motor in my 94 hatch, im having problems with vtec, it kicks in for 2 or 3 times but after that the check engine light some on and vtec dont work no more,even when its connected it loses power after 6,500rpm i conected all the vtec lines to the ecu. help!
Old Nov 8, 2004 | 07:14 AM
type_r_jon's Avatar
Default Re: vtec (b16racer23)
u got the correct chip, i hope. double check. i believe its p73
you may need a better fuel pump, injectors....did u upgrade ur fuel system?
Is it a new or used engine, u may not be firing out all 4 cylinders, u can do a compression test to check this
There r a lot of things that u could have done wrone. I gave u a couple to start with. Do a search on engine swapping. Oh and I wouldn't drive that car till u fix the problem.
Modified by type_r_jon at 8:29 AM 11/8/2004
Old Nov 8, 2004 | 07:19 AM
b16racer23's Avatar
Default Re: vtec (type_r_jon)
i got an obd1 p28 chipped ecu
Old Nov 8, 2004 | 07:25 AM
b16racer23's Avatar
i put an ls fuel pump and i have stock itr injectors
Old Nov 8, 2004 | 07:30 AM
type_r_jon's Avatar
the ls fuel pump is probably not cutting it homie, get urself an itr fuel pump and u should see an improvement.
Old Nov 8, 2004 | 07:40 AM
Mugen Mike's Avatar
Try the Hybrid Forum. Not too many people in the ITR Forum need to swap ITR motors into their cars.
Old Nov 8, 2004 | 07:45 AM
Jon D's Avatar
Default Re: vtec (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">Try the Hybrid Forum. Not too many people in the ITR Forum need to swap ITR motors into their cars. </TD></TR></TABLE>
Some do....
Old Nov 8, 2004 | 09:29 AM
prestonpark's Avatar
i dont think its the fuel pump,im using a stock old single cam fuel pump with my itr engine in my eg.
Old Nov 8, 2004 | 11:44 AM
92WhiteEG's Avatar
It definitely not the fuel pump.. well at least its not because he doesnt have an ITR fuel pump.. Ive had about every motor in ym car ranging form a b16, LS-VTEC, and now a ITR and still have the same old 92 cx fuel pump..
as for your problem.... what code is you car throwing, you cant fix the problem if you dont know whats wrong...
Old Nov 8, 2004 | 12:22 PM
99 TYPE R's Avatar
check ur oil mine poped n and outta vtec 2 quarts low
Old Nov 8, 2004 | 12:57 PM
b16racer23's Avatar
Default Re: (99 TYPE R)
what do u mean
Old Nov 8, 2004 | 01:01 PM
JinDIESEL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_r_jon &raquo;</TD></TR><TR><TD CLASS="quote">the ls fuel pump is probably not cutting it homie, get urself an itr fuel pump and u should see an improvement.</TD></TR></TABLE>
yep. for your hatch, you need either the stock itr fuel pump or an aem one.. and check the oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">Some do.... </TD></TR></TABLE>
hollahhhhhhhhhhh hahaha
Old Nov 8, 2004 | 01:04 PM
ITR184's Avatar
Check your oil pressure. Maybe the pump is going bad.
Old Nov 8, 2004 | 01:23 PM
b16racer23's Avatar
Default Re: vtec (Cod Sac)
what pump? oil pump?
Old Nov 8, 2004 | 01:42 PM
ITR184's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 &raquo;</TD></TR><TR><TD CLASS="quote">what pump? oil pump?</TD></TR></TABLE>
Yes. Also check your oil pressure sending unit. Usually if it is bad the oil light will come on, but since it's a swap I would check it. Or it could be the vtec solenoid itself. Just have to trouble shoot.
Old Nov 8, 2004 | 06:18 PM
92WhiteEG's Avatar
Default Re: vtec (JinDIESEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">
yep. for your hatch, you need either the stock itr fuel pump or an aem one.. and check the oil </TD></TR></TABLE>
This is 150% wrong!!!! you do not need a itr fuel pump and a bad fuel pump is not going to cause your vtec to fluctuate.
I would agree its probably something to do with oil... either low on oil, or your vtec preasure is faulty. Also check your vtec solinoid screen, make sure its not clogged.
Old Nov 9, 2004 | 10:00 AM
b16racer23's Avatar
Default Re: vtec (92WhiteEG)
its throwing check engine codes 17 and 21
Old Nov 9, 2004 | 01:05 PM
99 TYPE R's Avatar
did you check the codes, there is a code list on here so look it up u will need sum day and check ur oil like i said in the first place, what i mean is check ur oil, If you know how to!
Old Nov 10, 2004 | 12:18 PM
99 TYPE R's Avatar
almost positive it is an oil problem did you do anything yet or fix it?
Old Nov 10, 2004 | 01:20 PM
Opie's Avatar
Move this thread.
supergohan
12
Oct 7, 2013 05:43 AM
JDMh0ndaDC2
Nov 24, 2007 07:58 PM
ensracer
Sep 15, 2005 10:15 PM
Brick Top
Oct 11, 2004 04:08 PM
egSpoonR
Sep 8, 2004 02:43 PM
